I Got Screwed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JimN, Nov 2, 2010.
  1. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The morning started with frost on the car (again) and a lit TPMS light. Great. I pull into my pollling location & leave the car on to defrost. How long could this take? 7 minutes. When I come out I plug in my air compressor & get to work. The first 3 tires are 40psi, down 10 psi. The passenger front tire is 20psi. I'm pushing the compressor to its limits but I get all 4 back up to ~50 in a half hour or so. The ICE spins up a few times to warm up but the traction battery stays almost full. Off to the office.
    When I arrive I check the tp on the right side. Rear tire is up 1.5psi (driven 35 miles) the front is down 1.5psi. Wonderful. Five hours later I leave for the day checking the tire. Now it is down to 25. Pump it back up & go home. After today's errands I go to the dealer to get it patched. I'm shopping for paint & I figure if they damage the TPMS then it's between them & Toyota.
    "M" at Holman writes it up with only a perfunctory attempt to get me to do the recall & complimentary check. "Just fix the tire."
    No mention about the ScanGauge or insulation. They didn't lower my tp. I forgot to ask for 50psi in the tire & got only 35. I finished the job in their lot before I left. $24.70 (including 7% tax).
    At 15856 miles & 10 months from the inspection sheet: Battery 468 cca, 12.98v, tread 8/32 all around, front brakes 80%, rear 89%.
    I wandered around the showroom & lot & was left alone. On my return from the Parts Dept I was almost run over by my own car. I didn't realize just how quiet it is.
    Ovrall a good dealer experience.
  2. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Been there, done that. Twice.
  3. JimN
    7,028
    1,116
    South Jersey
    Why do tire problems only happen in unpleasant weather?
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I know the difference between a screw and a bolt. I've never been bolted.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    This seems like a classic physics experiment.
    PV=nRT
    Temp goes down - maybe pressure follows???
    Of course, tracking the volume as the tire expands, may be a bit more difficult....
  6. JimN
    7,028
    1,116
    South Jersey
    I attribute the 10psi to the weather & time. I'm not sure the volume expands as the tire's appearance didn't change between 20psi and 50psi.
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I've read that each 10 degF change in air temps results in ~1 psi change
    in tire pressure...
    I wonder how fast the pressure in the tire reacts to temp changes...
    mere minutes or over a few hours?
    Then there are pressure changes from temps due side wall flex and
    tread squirm, about which I know nothing.
    Funny though, today I got "nailed." Within 50 ft of my driveway TPMS
    light went on. Nail in sidewall, ~1/2" above tread. Air leaking out so
    fast you could hear it. Damn. Immediate fix required. Pump it up,
    back into driveway, mount spare.
    New tire... ouch!
  8. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    Get a NITROGEN fill. This should remedy the problem with TP + -
  9. fuzzy1
    10,045
    Does NITROGEN have a legal exemption from the gas laws?
    2 people like this.
  10. JimN
    7,028
    1,116
    South Jersey
    Changes due to ambient temps seem to take hours. I can get a 2psi difference between the sunny side & shady side of the car.
  11. DavidA
    2,325
    1,811
    Chicago western burbs
    Jim, you don't happen to have Toyo's on your V, do you? I've had two bad tires in 6,000 miles.
    Normally, tires don't lose much air, but occasionally, when the temp drops to about 30 degrees F, a tire can lose 20 lbs. in a few hours. Or it could be fine for two weeks. I haven't figured it out yet. I think there's a bad combination with the aluminum 17" wheels and the tires Toyota chose to use.
  12. JimN
    7,028
    1,116
    South Jersey
    Yes, they are Toyo tires. Last winter I didn't notice large fluctuations (bought late December), at least I don't remember any.
  13. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    humm, 'Discount Tire' fixes flats for free in my area....and you can stand there and WATCH them work on your tire.
  14. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Correct.
    For ideal gasses in the vicinity of ambient T and typical tire pressures it's very close to 1 psi for every 10 degrees F.
  15. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    As to the speed of ambient temps affecting tire pressure,
    a simple demonstration:
    (My middle school STEM students who have done this
    demo/experiment recently find it to be a constant source
    of wonderment...)
    Place empty 2/3 liter soda/cola/"coke" bottle in freezer.
    Wait ~3 minutes.
    Remove bottle from freezer.
    Voila! PV=nRT comes alive!
    The cooling takes but minutes.
    Observe bottle as it returns to ambient temp.
    I suspect that for tires there is some delay due the mass of
    the tires themselves also needing to cool to ambient.
  16. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    I had a similar situation on a different car, and it wound up being the rim. Is it the same wheel in your case when it does this? In my case, it was the 3rd set of tires on the car, and rust had built up on the rims (probably due to my lack of using nitrogen:p). I do not know why, but it was a 'come and go' sort of thing, and it happened in winter. Buffed the rust off, no more problems. In your case, with such a new car, I doubt it would be rust, but it might be worth looking into seeing if the rim is out of round. Have you hit a pothole hard or anything? (If it's more than one wheel, forget everything I said...).
    Good luck
    ~T
  17. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    :eek:... and what would Mr. Boyle have to say?
    ;):amen:
  18. DavidA
    2,325
    1,811
    Same tire/wheel every time. Not hit anything hard and its had random losses since nearly new.
  19. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    The issue might be a not fully tightened nut on the TPMS valve stem.
  20. Charlie Lear
    Charlie Lear Newbie Evangelist
    Melbourne, Australia
    "I got screwed" - ha - YOU got screwed? I got screwed more than you!
    Stopped at a rail crossing, people in the next lane pointed out nearly-flat rear tyre (obUStranslation: tire).
    Pulled over, called wife to come down and rescue the kids (of course it was 10 minutes into a 50 mile trip, and they were performing in a play and time was of the essence) while I rescued the car.
    Small screw in the tyre.
    Pull out the inflation kit (this is an iTech, doesn't come with a space saver spare in Australia) and figure out the instructions.
    Inflate the tyre full of goop, run it home.
    Call around the tyre shops the next day, gooped tyres can't be repaired, nobody has any Bridgestone Ecopia B250 in the right size. Bingo! One Bridgestone shop has one, but its the V-rated not H-rated. Fine, I'll take it. $240. Ouch.
    Call Toyota to get a replacement bottle of goop. "How much?" "It comes as a kit, the sealant plus the opening key and a hose." "Yes, I know that, how much?" "$165."
    "OK, how much for a space-saver spare?" "We don't sell them as a spare, only the rim and tyre separately." "OK, how much?" "$225 for the rim, $195 for the tyre."
    So! $405 every time I pick up a nail or screw. Or $420 for the bright yellow option with a rubber band stretched around the outside.
    You tell me who just got screwed.
