I had my Prius 10 hours and it's already in the shop
Discussion in 'Gen 2 Prius Technical Discussion' started by Metalkitty, Aug 20, 2007.
  1. Metalkitty
    Metalkitty New Member
    Alright folks, I 'm highly discouraged and need some advice. I have been saving up and anticipating the purchase of my first ever brand new car. After careful research and budgeting I decided on the 2007 Prius.
    This past Friday night I bought a new Prius and left the dealership at 9:30 pm. At 7am the next morning I start the Prius and the check engine light is on. I drive directly back to the dealership expecting something minor like gas cap loose, etc. Maintenance person tells me that the diagnostic report came back with a code about the coolant. Being unfamiliar with this code he asked to keep the Prius until Monday. Then he could call Toyota and decide what needed to be done.
    Late this afternoon I called the maintenance department only to be told that the car was there and a new part had been ordered. The new part was a COMPUTER. They had ordered a new computer for my car. Red flags are going off in my head. Why would my brand new car need a new computer? To me, it seems that the dealership sold me a broken car. I know all about he lemon law and it's stipulations. None of that will help me now. What is bothering me is I bought a brand new car that doesn't work and now the Carfax report will show that the computer had to be replaced, hence depreciating the resale value.
    I only got to drive the Prius home from the dealership and back again! Any suggestions of what I can or should do?
  2. Swanny1172
    Swanny1172 New Member
    666
    Some cars are lemons and the Prius is no exception. It is subject to manufacturing defects just like every other car on the road. Keep documentation of the repair, because the Lemon Law may very well be your friend here.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I wouldn't worry about it at this point. Unless you anticipated a short turn around time for selling the car the part replacement won't matter.
    Stuff happens. Although we want every one of the 1million + Prius sold to be perfect when we drive it off the lot that's a tad unrealistic. You got a bit of bad luck with yours. I suspect it will be perfectly fine once it's fixed properly.
    Certainly if it's a persistant problem or they can't find a solution then take advantage of the lemon laws and make them replace it with a different brand new one.
    I can only imagine how disappointing and frustrating it is after getting excited, saving up and anticipating like you have. I'm sorry for that for you.
  4. boulder_bum
    boulder_bum Senior Member
    1,371
    38
    Castle Rock, CO
    Did you ask the dealer if they can simply give you a different car? Might be worth a try.
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    that's why you've got a basic warranty, my friend. manufacturing defects happen anywhere they make things. prius computers are no exception, as much as we'd all like to think otherwise. clearly this one wasn't done right and it appeared right away, as do the vast majority of manufacturing defects when they're driven off the lot.
    sorry you got a bad computer, but know that it'll be fixed up on toyota's dime and you'll be happy driving your new car again soon!
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Electronic devices have a higher failure rate during the first few hours of operation. In the electronics industry, we refer to this as "infant mortality", which is kind of a grim term, but it gets across the idea. Once an electronic device has worked for a few hours, it's likely it will keep working for a long time, unless it is somehow misused or mistreated. Your computer was one of those unfortunate ones that failed. Replacing it will do nothing to hurt your new Prius. It's not like bending the frame in an accident. Your new Prius will be fine.
    Tom
  7. patsparks
    10,664
    567
    Adelaide South Australia
    It happens. :unsure:
    You have been unlucky but it isn't the end of the world or the love affair that will soon bloom between you and your car. It's an inconvenience and perhaps a little embarrassing but at the end of the day you will have a great car, which feels terrific to drive. :D
    One fault no matter how bad doesn't make the car a lemon, keep all documents relating to the repair just in case but remember Toyota's legendary reputation for reliability didn't come out of a corn flakes pack, it was well earned.
    Infant mortality, there you go, tell your friends you were a victim of infant mortality. Love it, some computer nerd must have come up with that term. :blink:
  8. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Our dealership has a 30-day warranty that says that if you don't like the car you bought, you can give it back and get a different car from them. You can't just get your money back, but you can "trade up" or get a different model/color... whatever.
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Metalkitty, welcome to the site. Although this experience is upsetting give the dealer a chance to make things right. You should be driving a free loaner now. If you want to swap the car, ask the dealer. See if they will give you a few coupons for oil changes or a deep discount on the rear bumper applique. Once you have the car back and you have calmed down you will have the chance to express your opinion on the customer satisfaction survey. Everything will be fine, just relax.
    If it were a GM car, Mr. Goodwrench would have told you the CEL is supposed to be on. ;)
  10. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    It's an imperfect device designed and built by imperfect beings.
    As Swanny pointed out, if things keep cropping up you might have a lemon on your hands...otherwise, with any luck the dealer will make it right and you'll be on your way.
    I'm still a bit scared of the rocket science going on when I push the power button, but I'm getting better every day...
  11. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(Metalkitty @ Aug 20 2007, 06:16 PM) [snapback]499388[/snapback]</div>
    1) Write down in your owners manual and/or maintenance manual what was replaced and the milage.
    2) Enjoy the car.
    I have a 2001 and have had over time more than a couple of parts replaced. This included tires that wore out very fast, a new gas tank, new main battery. However, Toyota does a really good job of getting parts replaced and fixed under warranty and has a pretty decent approach to minimizing the inconvience. Please plan on a thing or two happening over the years. (Even people get sick now and then.) Also plan on saving a whole bunch of gas over the years as well.
    Now if you think that this is a big worry, please get a Chrysler and see how long you visit the dealer on average.
  12. paulrubin
    paulrubin New Member
    32
    You can certainly feel annoyed. I'm expecting to get mine in about 2 weeks and I'd be furious but then you settle back down and realize that cars do typically need repairs and electronics tend to go bad very quickly or not for a long time. I wouldn't worry about a CarFax report though. That report, to the best of my knowledge, is not about repairs of this nature. It's comprehensive but I don't think THAT comprehensive. It will show for a cars' various owners, title info, odometer readings, likely warranty coverage, whether the vehicle has ever had an accident (like my recent accident that got me Prius shopping) that required it to be "totaled", major body damage repairs to the frame, whether the airbags were ever deployed (at least in an accident, not sure about if they simply malfunction), time in a body shop, fire damage, odometer tampering, and recall info. A straightforward replacement of a component that goes bad is, to the best of my knowledge, not part of the carfax report and therefore doesn't really factor in to depreciating your car beyond the overall general model year, condition, number of miles type stuff.
    As to the lemon law, I know that varies by state but as a general rule it relates to a recurring problem that the dealership's service department is unable to resolve after multiple attempts (probably 4-6 sounds about right to me) or possibly, a rather large number of unrelated issues that keeps the vehicle out of your service for a substantial amount of time within a set timeframe. I'm sure there are others here with more experience than I have in this matter but I'm pretty sure I'm in the general ballpark.
    You can certainly try to get a replacement Prius but my own experience tells me that you may have a problem getting precisely the same package in an acceptable color in a reasonable time frame. Electrical problems can sometimes get complicated but it's very important that you document everything, keep all receipts, make notes about phone contacts, etc. for all repairs and service. Most of the car manufacturers will be far more accommodating if they know you're on top of this stuff and can prove the vehicle's been taken care of properly and you are a nitpicker on the records. Only once in some 25 years of car ownership to date did it ever become a real issue for me but it happened to be on one of the few cars I was meticulous about recordkeeping and the result of dealer negligence and we were able to work out an acceptable deal in a car swap.
  13. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    It's worth reemphisizing Paul R's advice. Keep your own records in detail and make sure you initial or sign your records. Makes them a legal record.
  14. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Does this "dealership" have a name?
  15. Metalkitty
    Toyota on Nicholasville
    <div class='quotetop'>QUOTE(zenMachine @ Aug 21 2007, 03:39 PM) [snapback]499880[/snapback]</div>
  16. zenMachine
    3,355
    300
    <div class='quotetop'>QUOTE(Metalkitty @ Aug 21 2007, 03:42 PM) [snapback]499912[/snapback]</div>
    Did they say "which" computer had problems?
  17. Errel
    Errel New Member
    24
    <div class='quotetop'>QUOTE(Metalkitty @ Aug 21 2007, 04:42 PM) [snapback]499912[/snapback]</div>
    Sorry to hear about your bad experience with your brand new Prius. Looking at the positive side at least you are still covered under warranty. Toyota dealerships, as far as my experiences with them, are very reliable.
    I live here in Northern VA, DC area. (I am not working for Toyota :) I hope the dealership let you use a loaner, a Prius too. I hope that your dealership will fix your problem to your satisfaction. If not, report them to Toyota. Good luck.
  18. Metalkitty
    The one that controls the coolant. I will specifically ask tomorrow.
    <div class='quotetop'>QUOTE(zenMachine @ Aug 21 2007, 06:09 PM) [snapback]499964[/snapback]</div>
  19. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    <div class='quotetop'>QUOTE(patsparks @ Aug 20 2007, 04:59 PM) [snapback]499403[/snapback]</div>
    Actually, that term has been around long before computers became everyday objects. Way before the days of integrated circuits and transistors, the phenomenon existed for devices like vacuum tubes (anybody else remember those?).
  20. qbee42
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(RedRockPrius @ Aug 23 2007, 12:00 PM) [snapback]501015[/snapback]</div>
    Yes, I remember them. We used them to keep radios warm. :D I still have my Picket Power Trig slide rule and leather case. I never use it, but I can't stand to toss it either.
    Speaking of tubes, remember the tube testers at drug stores and places like that. You would bring in a suspect tube from your TV, plug it into the tester, and get back the "bad" reading. They always tested bad. The base of the tester contained replacement tubes. Long live the 12AU7!
    Tom
