I have 2012 model prius showing srs airbad and triangle sign
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xamza, Apr 7, 2019.
  1. xamza
    xamza New Member
    16
    lahore
    Hi everyone,
    I have 2012 model prius its showing me srs airbad and triangle sign. I scan it with obd2 tools and it give me 2 codes. P3107 Lost communication with airbag system control module in hybrid system and B1618 Front airbag sensor initialization error. any one please guide me is it ECU issue? because i try to remove it but its not going. I'm also attaching the image. Looking for the answers,
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    Give us a little history about your Prius, i.e., mileage, accident history, recent repairs, etc.
    Eric34 likes this.
  3. xamza
    xamza New Member
    16
    lahore
    Thanks a lot for replay. Its almost 99000 driven. recently catalytic converter has some issue i got it fixed. recently around 1 month ago. the car is not been to any accident. before this battery code comes some times but by clearing it from scanner its gone and comes after 400 km.
    51,715
    what battery code are you getting?
  5. Chuba
    Chuba Junior Member
    45
    Nigeria
    May I ask.
    I have 2012 prius front accident with driver airbag and kneel airbag blown. I have P3107 could this code cause any of This? Check hybrid system and triangle of death?
  6. bisco
    51,715
    definitely an airbag code
  7. Chuba
    Chuba Junior Member
    45
    Nigeria
    But could that cause check hybrid system and triangle of death?
  8. bisco
    51,715
    yes, but it could be something else as well. and damaged hoses or wiring in the front end?
  9. Eric34
    Eric34 New Member
    Sacramento
    Check connectors, check fuses. That is all I could other then taking it to a shop.
    Check the plastic abs sensor connectors, under the driver seat.
    #9 Eric34, May 6, 2020
  10. bisco
    51,715
    rodents?
