I have 35 different codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LuisPrius08, Jan 11, 2021.
  1. LuisPrius08
    LuisPrius08 New Member
    Washington DC
    87,234 Miles Wth Is Wrong My Prius. Why Are These Codes Are Here? I Changed My 12V Twice. Car Dies After About 5 Minutes. I’ve Gotten Techstream Out Off My Friends Computer. I Can’t Figure This Out.
    P0A0F
    P0571
    P0A37
    P0A93
    P0A94
    P0A08
    P0A09
    P0A80
    P3000
    P3013
    P0300
    P0303
    P0304
    P0420
    P3190
    P0A2B
    P0010
    P0016
    P1455
    C0200
    C0210
    C1235
    C1237
    C1241
    C1247
    C1252
    C1256
    C1259
    C1300
    C1312
    C1314
    C1310
    C1365
    C1391
    B1271
    B1475
    B1803
    B1813
    B2775
    B2794
    U0100
    U0111
    U0131
    U0293
    12V 9.00 OFF 9.50 ON
    BB1 16.00
    BB2 16.02
    BB3 15.21
    BB4 16.07
    BB5 16.08
    BB6 16.06
    BB7 15.99
    BB8 16.11
    BB9 16.20
    BB10 16.00
    BB11 16.15
    BB12 16.00
    BB13 16.00
    BB14 16.10
    52,436
    'techinfo.toyota.com' might be corrosion
    what does the 12v read at the jump point under the hood after the car has been off for a few hours, and then, what does it read after you turn on the headlights for 15 minutes ?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Why do you think you SHOULD be able to figure it out ?
    I think you need a shop visit.
  4. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Have the two 12 volt batteries been new batteries that you have installed?
    Clear all the codes with Techstream and see what comes back. Remember to note the sub codes associated with all primary codes. Then take inventory and see what is what.
    richiemoe2 likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    12.9. Off
    9.5. On
    is so blown inverter.
    SFO likes this.
  6. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Did you reverse polarity jump start it along the way and blow the car up?
  7. ChapmanF
    18,626
    Can you give a little more detail here, what was measured and in what circumstances?
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Stop trying to start the car. It isn't running, rather it sounds like it's running but it's more likely just the weak and rapidly getting weaker HV battery trying to start the misfiring ICE. The 12v just boots up the car, the HV battery starts the ICE.
    My guess: inverter or inverter pump died but car was still driven (or left on) eventually bringing down both the 12v and the HV systems as neither are now getting a charge. Also if original, the HV battery is probably toast.
    GOOD LUCK!
    richiemoe2 and edthefox5 like this.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    12V battery reading = 9.00 OFF 9.50 ON
    9 volts off and 9.5 volts on?
    You clearly have a 12v system issue, possibly including the DC to DC converter inside the inverter. Resolve that first before you mess with anything else. That low of a 12v system can easily be the source of triggering many of your codes. Maybe voltage readings at the underhood jump point would be more appropriate. Another question is whether the 9x volts is due to a weak battery, bad connection, or a large load drawing it down. It would need to be a pretty significant load to draw the inverter down to 9.5 volts while in ready.
    The HV battery has a weak module in Block 3, but the others look ok. The car must have been in ready condition recently, because the other blocks are all 16.x volts, which means 8v+ for each individual module. The only way you're going to have 8 volts per module is if the HV battery has recently been under a charge condition.
    IF you have previously attempted to jump the 12v system, and applied reverse polarity, you have most likely burned open the main fusible link located on the passenger side of the underhood fuse box, along with a couple collateral fuses in the same box. When the fuse box is in this condition, I've seen the brake pump run continuously and put a severe drain on the 12v battery, depleting it fairly quickly. This can be stopped by removing the 2 abs relays. (or at least that's how I stopped it to allow further troubleshooting). The further troubleshooting revealed the owner did a reverse polarity jump.
    Can you provide some details as to what has occurred with the car since the last time you actually drove it successfully? What happened that caused you to first need a new battery?
    #9 TMR-JWAP, Jan 12, 2021
    SFO likes this.
  10. LuisPrius08
    Washington DC
    I let the car sit October-January
  11. bisco
    52,436
    luis?
  12. LuisPrius08
    Washington DC
    Yes what’s up
  13. fotomoto
    5,639
    3,815
    So. Texas
    AKA Final nail in the coffin for the OEM HV batteries 12 years later. The timing of the pandemic and the EOL for gen 2's batteries has been nearly a perfect storm.
    GOOD LUCK!
    edthefox5 likes this.
  14. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    @LuisPrius08
    Are you saying:
    Is the answer to this question:
    if nothing else has been done with the car, like no jump starts, battery installed backwards, etc, then you likely just have a 12v installation problem.
  15. bisco
    52,436
    you have help here :)
