I have a pre 4.0 scangauge will it work on 2015 C?
Discussion in 'Prius c Accessories and Modifications' started by priustexasbob, Dec 28, 2015.
  1. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    I found my old scangauge, pre 4.0 firmware. will it work on my 2015 C or should I send it into have the firmware updated?
  2. vskid3
    vskid3 Active Member
    773
    228
    Why not just try it? The basics should work fine, it's the xgauges that might give you problems. Also, make sure it turns off. Don't want to go out to a dead battery the next morning.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    …you might consider calling the ScanGauge guys to ask about an upgrade! I bought my second SG-II from eBay, and found it was an earlier firmware version, they (ScanGauge guys) sent me the latest firmware (new board, plus installation instructions) free and no charge! (…thanks guys!) :)
  4. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    How do you know if it's off or not?
  5. Dave14Prius
    Dave14Prius Member
    72
    26
    NE Missouri
    The screen goes dark
  6. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    There's two modes on the scangauge for sensing when to turn gauge off, 0 RPM and NO COM. Make sure you set up the scangauge to hybrid and make sure it isn't set to turn off when zero RPM is sensed, but when no communication through the OBDII port is detected.
    Dave14Prius and vskid3 like this.
  7. Sean Nelson
    421
    182
    Got it, thanks!
  8. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    thanks for the reply's, I wanted to check first to make sure it wouldn't do anything odd.
  9. xliderider
    8,056
    3,223
    Honolulu, HI
    If you have it registered with linear logic you can send it in for an update. Email them, you might be able to update it regardless.
  10. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    I did plug it in and it works just fine. so much disinformation on the internet *** gasp *** one site said it would not work and might even damage the car. ???? huh???
