I have a "problem"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Phoenix, Oct 21, 2016.
  1. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I have a 2008 Prius with 214,000 miles, lately and with increasing frequency but no real pattern I get the red triange and the word problem on the screen. It doesn't stay on and they is no noticeable changes when this happens. So now I have a problem because I don't know what it is...at all. Is there a way to get into some vehicle diagnostics without tech stream or taking it to a Toyota dealer. I did manage to get some information when I was checking the voltage of my 12v but I've forgotten the procedure. Any help would be greatly appreciated and I will also try to look for similar posts as well. Thank you.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Many Auto Parts stores have an OBDII reader you can use. They usually expect only one ECU, so they do not check all the ECUs in a Prius, but if it is an engine 'problem', they may find it.
  3. JC91006
    16,827
    8,600
    A common problem has been the failure of the inverter coolant pump. Open the cap and check the reservoir fluid and see if it has any movement while the car is on.
  4. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I have a scan gauge and it does not register any engine code. I will check about the coolant, but the one thunk I have documented that was done was replacement of the pump
  5. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    A low engine oil level can cause the intermittent appearance of the red triangle. When was the last time you checked it?
    #5 jadziasman, Oct 21, 2016
  6. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I think you solved my problem jad, I'm overdue for an oil change and my sometimes aggressive driving style does burn a bit of oil...I will check that right away
  7. JC91006
    16,827
    8,600
    Oh yes, always check oil level first. But you shouldn't get to the triangle warning, that's already late
  8. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
