i have required info about transmission oil change in prius c name aqua 2013 odo 120k ?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ehsan, Jan 2, 2020.
  1. ehsan
    ehsan Junior Member
    Pakistan
    2013 Aqua
    toyota aqua (prius c 2013) have odo reading 120k should i change gear transmission oil and how properly should i change in my country mechanic are not following the right method to change the oil they done it in a simple way like put from filler plug if coming out then they put filler plug ? i have read in manual that there is specific temp that to chek the correct level ? so what should i do ?
  2. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    For the Prius "c" Trans,
    You need to jack up all four corners of the car. You need to have car level to do the job correctly.
    First, loosen the fill bolt, to make sure you can fill after emptying.
    Second, loosen the drain bolt and empty out the fluid
    Third, replace the drain bolt and torque, then use funnel with a hose placed into the fill hole.
    The "c" should take 3.5 qts (not sure on metric) of Toyota WS fluid
    When full, it will basically start to overflow that fill hole.
    Then you can hand thread the fill bolt and torque tighten it.
    You will need the 10mm hex bit or allen socket for the plug
    I did take as short drive before changing mine, but I dont think there is any certain temp necessary.
    Hope you can understand this enough to DIY
    Mendel Leisk and bisco like this.
  3. topshot
    topshot Member
    145
    57
    Midwest
    2015 Prius c
    What are the torque specs?
  4. Mendel Leisk
    41,108
    I'm not sure, but third gen prius drain and fill bolts are both 29 ft/lbs. Get a proper allen key style socket, that can be snapped onto ratchet or torque wrench, 10 mm hex.
    I haven't found a Prius c Repair Manual yet, fwiw.
