i have toyota prius 2012 three
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Abdallah Elkei, Mar 24, 2019.
  1. Abdallah Elkei
    Abdallah Elkei New Member
    Philadelphia PA
    i see four light come on my dashboard going and come back every time and i change the battery 12 v and i do restart two time and nothing happen what can i do
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Bad wheel bearing
  3. Abdallah Elkei
    Philadelphia PA
    I changed before one weak ago
  4. Mendel Leisk
    38,728
    What was changed, battery or wheel bearing?
  5. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    I had the same problem! Took it to the dealer (i work there) they thought it could've been a speed sensor. Turns out that that the sensor on the back of the wheel bearing was non-functional so you may have replaced the wheel bearing but if the connector wasn't attached properly it could be malfunctioning. The only sure fire way to fix it would be to get another wheel bearing.
    If you changed one recently the one on one of the other wheels could've gone bad.
  6. tankyuong
    1,555
    660
    Central MO
    Or hook it up to an abs reader and check speed on sensors while driving
