I installed an AC compressor and a condensor on my 2007 prius. Now I m having a red exclamation mark
Discussion in 'Gen 2 Prius Main Forum' started by Asif Mehmood, May 8, 2019.
  1. Asif Mehmood
    Asif Mehmood New Member
    Pakistan
    After installing these 2 parts. I drove it for a while and suddenly after turning it off and restarting it. I saw red exclamation mark plus 4 yellow lights. Can anyone explain it to me why it happened . Thanks.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Using a hybrid capable OBDII scanner pull the codes its throwing and post those codes back here. The car is telling you exactly why its unhappy. My guess is the hybrid battery has failed. Or you killed the 12 volt battery installing the parts leaving the doors open lights on.
    Without the codes anything else is just a guess.
    Skibob and Raytheeagle like this.
