I installed the Block Heater last night
Discussion in 'Gen 2 Prius Main Forum' started by gforeman, Nov 20, 2007.
  1. gforeman
    gforeman New Member
    83
    The instructions here were very helpful. My right arm looks like a cat scratched it :D My that little thing gets slippery when you coat it with the grease! It took me more time to route my cable than actually installing the heater pin.
    A few questions...
    1. At what temp do you start plugging it in?
    2. How long do you have it plugged in/on before your departure?
    3. What is the grease for? Just thermal transfer?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    1) I use it all year around...serious benefit starts showing up at any temp below 60.
    2) 3 hours seems to be the optimal time as far as increase in temp vs energy used....longer plug-in times will get the ICE temp marginally higher, but 3 hours seems to be the best cost/benefit point. If you have a regular schedule for departure times use a timer.
    3)Yes, thermal transfer.
  3. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Congrats! Evan gave the answers, but I'll tell you the arm will heal fully within the month.
    Wayne
  4. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    Unless you keep installing them like Wayne does.
  5. gforeman
    gforeman New Member
    83
    <div class='quotetop'>QUOTE(Skwyre7 @ Nov 20 2007, 10:51 AM) [snapback]541963[/snapback]</div>
    Once is enough :D
  6. satwood
    satwood Member
    107
    16
    Webster, MA, New England, USA
    2014 Prius v wagon
    <div class='quotetop'>QUOTE(G-Man @ Nov 20 2007, 07:53 AM) [snapback]541900[/snapback]</div>
    Where did you buy your heater? I have been looking for one and can not find it online.
    Thanks in advance
    Steve
  7. keith999
    keith999 Junior Member
    Catoosa, OK
    I am also interested and cannot find where they are for sale. Please let me know as well.
    Keith
  8. FireEngineer
    1,247
    124
    If you want a block heater try the PriusChat shop or www.metrotpn.com.
    Wayne
  9. KSlauson
    KSlauson Junior Member
    Wasilla, Alaska
    2002 Prius
    <div class='quotetop'>QUOTE(FireEngineer @ Nov 21 2007, 06:20 AM) [snapback]542393[/snapback]</div>
    Wayne,
    I popped over to Prius Shop, and cannot find any listing for a block heater. Over at metrotpn, they have this notice: BLOCK HEATERS ARE NOT AVAILABLE, HOWEVER WE DO EXPECT SOME SOON . PLEASE CHECK BACK FOR A NEW ANNOUNCEMENT SOON. (11/02/07)
    So I guess I'm out of luck for awhile. It snowed a bit last week in Wasilla, conveniently while I was in Madison and Chicago, but my Alaskan Prius was snug in the garage. I'll just wait patiently for the next group buy, I guess. It's about time to trade out my wife's Grand Caravan for something newer too, and I'm seriously considering a 2006 or 2007 Prius if I can find one.
    Madison sure has a lot of Prii. From my daughter's house I could easily fit three in my camera viewfinder. I've attached the picture: [attachmentid=12556]
    Ken
  10. ToddWess
    ToddWess New Member
    40
    Fairfax, Virginia
    <div class='quotetop'>QUOTE(efusco @ Nov 20 2007, 08:40 AM) [snapback]541907[/snapback]</div>
    Just need some clarification on this . . . because I'm confused . . . you run an electric heater for three hours before running your car to save gas??
    What about the fossil fuels that are burned to generate the electricity for the heater for three hours from the local power grid?
    And you're paying for that three hours of electricity on your utility bill . . . and an electric heater uses a TON of electricity . . .
    Not trying to change any minds or anything, just looking to be educated in case I'm wrong on the issue.
    Thanks,
    Todd
  11. Silver Surfer
    Silver Surfer Junior Member
    38
    Asheville
    <div class='quotetop'>QUOTE(Stephen Atwood @ Nov 20 2007, 11:38 PM) [snapback]542264[/snapback]</div>
    I have one, Email me if interested.
    I purchased one through the site and do not think I will tackle installing it.
    Jim
  12. Doc Willie
    1,717
    142
    Out there, somewhere
    <div class='quotetop'>QUOTE(ToddWess @ Nov 22 2007, 06:23 PM) [snapback]543011[/snapback]</div>
    Somewhere on this forum, somebody did the math. IIRC it comes down to 1 cent of electricity saves 4 cents of gasoline in normal usage.
  13. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Well, up here in the frozen north, we always plug in our cars. There is a huge benefit to partially warming up the motor before starting it, especially in temps colder than 0 F. At temps of -30 F and colder, a block heater usually means the difference between getting started and needing a tow to a garage.
    The Prius really doesn't have a "block heater" as it doesn't heat the engine coolant directly.
    There is a machined hole in the block that the Prius heater plugs into. The purpose of the thermal transfer grease is to ensure even heat transfer from the heater to the aluminum block. It's a small heater, only 400 watts.
    Based on my power rates in Manitoba, it costs around 2 cents an hour to leave the car plugged in.
