I just changed my rear brake pads at 200k. It still had a few thousand miles left on it.
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, May 9, 2022.
  1. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    It's amazing how long brake pads and drums last on these Prius cars. I changed my front pads at 170k and rear drums at 200k. After changing these pads my parking brake felt very tight and new. Also it was very difficult to do these drums and after doing the one side first the second set was much easier. I would suggest getting a mechanic to your rear drum unless you have tools and very mechanically inclined. 20220422_160645.jpg 20220422_160638.jpg 20220422_160635.jpg 20220422_160509.jpg 20220422_160505.jpg
    SM-A526U ?
    51,944
    it is amazing, well done!
    and i would add, find the right mechanic. many can easily botch these jobs.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,156
    6,313
    Texas Hill Country
    My 2012 v wagon has rear disks and rear parking brake shoes. At 250,000 I changed the rear brake pads just because I was there with a howling wheel bearing/hub. The pads were still legal and would have made 300k miles. The front pads and rotors are original as are the rear parking brakes and rotors. Regen saves gas; careful use of regen saves gas and brakes.
  4. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Are your struts original too?
  5. Kaptainkid1
    308
    247
    Los Angeles
    Yes. I have a wheel spring rubber spacer. It helps when I have a heavy load in the rear.
    SM-A526U ?
  6. Tombukt2
    Tombukt2 Senior Member
    12,989
    2,328
    Durham NC
    Brake pad material breaks down badly after time n heat cycles 3 yrs in mine they coming out with cracks in material and all of it Gen2 shoes gen3 pads pads. all park shoes last lifetimes. My parkie never been applied in Gen2 and 3 as of this date
