i just recently replaced my brake master cylinder but now my brakes will not respond when pressed.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Michael Kusi donyina, Mar 15, 2025.
  1. Michael Kusi donyina
    i just recently replaced my brake master cylinder but now my brakes will not respond when pressed.does anyone have any tips or solutions to help me out
  2. ASRDogman
    ASRDogman Senior Member
    7,109
    3,713
    Did you use techstream or other device to run through the bleed procedure?
    Brian1954 likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,486
    5,810
    Texas Hill Country
    Also, was it new and ordered from a dealer who verified the part through your vin?
  4. Michael Kusi donyina
    it was new.i ordered it through a dealer.i just bled the brakes but now i have a leak from the the buttoom of the cylinder.
  5. Michael Kusi donyina
    i did the bleeding process by just opening it and letting the fluid come out.
  6. bisco
    51,011
    you'll need to fix the leak and bleed the brakes with a proper scanner
  7. bisco
    51,011
    this guy says you don't need a scan tool watch
  8. ASRDogman
    7,109
    3,713
    To JUST bleed the brake fluid, you wont' need any special tools.
    But if you replace the master cylinder and/or pump, you NEED a special computer,
    to do it correctly, and make sure the brakes work.
  9. rjparker
    9,486
    5,810
    Texas Hill Country
    Agree. Bleeding a good Prius Master Cylinder is straightforward. However a replacement master cylinder needs all the passages inside bleed through a special Techstream process and it need its linear solenoid calibrated. There are few aftermarket very high end scanners capable of doing it and maybe the Autel AP200 depending who you believe.
  10. Michael Kusi donyina
    Do you think this is the reason the master cylinder is leaking from the buttom.as soon as I put the brake fluid inside the reservoir it comes straight out from under the master cylinder.I made sure everything was screwed on tightly it’s coming out of one if holes that stay opens and isn’t support to be closed or screwed In with a bolt
  11. Michael Kusi donyina
    this is the video i watched to learn how to bleed it the bleeding process was done just like this but when i went to pour fluid in the reservoir it just came straight out of buttom brake master cylinder
  12. rjparker
    9,486
    5,810
    Texas Hill Country
    You have a leak pure and simple. The proper Techstream process won't fix the leak.
    I don't know about an opening that has no connection but if true it should not be leaking fluid.
    It may require you to remove the part and carefully inspect each hydraulic connection. Also inspect the open "hole" for threads or plugs on your old master cylinder. It's possible plugs are not tight on your new part or simply missing.
    Another resource can be pics on ebay of used parts. Sometimes salvage yards cut off lines leaving segments providing clues.
    Example
    10-15 TOYOTA PRIUS ANTI LOCK ABS BRAKE PUMP MASTER CYLINDER BOOSTER SET OEM | eBay
    #12 rjparker, Mar 17, 2025
