I just saw a new screen
Discussion in 'Prius v Main Forum' started by Turquo, Jul 22, 2020.
  1. Turquo
    Turquo Junior Member
    17
    2017 Prius v wagon
    The screen was split with the left half doing Energy I guess and the right half doing Nav
    The screen I saw was on the left and was a circle with Engine in the top right and wheels in the top left and battery at the bottom. Arrows flowed between these icons as the power distribution changed.
    I've not seen this one before and while it's probably giving me the same info as the one that shows the chassis of the car, to me it seemed way more intuitive .. and useful
    2017 v Five with ATP if that makes a difference
  2. Tideland Prius
    16,621
    Yeah that's the compact version of the Energy Monitor (first showed up on the 2007 Camry Hybrid when it had the small monochromatic LCD screen between the gauges for models without navigation).
    Your trim level does make a difference as only the Prius v trims with the integrated Toyota navigation have the split-screen functionality. The lower trims use a DisplayAudio system with a Garmin-like interface that is separate from the Toyota/Denso version.
  3. Monica Harmon
    Monica Harmon New Member
    San Francisco
    Very useful function. My brother has the same
  4. vvillovv
    vvillovv Senior Member
    4,331
    1,514
    NY
    I use that screen sometimes too, especially when I want to make sure the ICE / Internal Combustion Engine / gasoline engine is running. It may be a bit different looking in the Prius Prime, but it was easy to know what you were talking about from your description.
    Welcome Monica, yep, I agree.
