I must have initiated the EV mode by accident!?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by autovolume, May 19, 2008.
  1. autovolume
    autovolume New Member
    I was trying to deactivate the safety belt beep following instructions found on PC. after completed the procedure, I took my car around the block and the first thing I noticed was that the gas engine wasn't kicking in!
    I kept driving around It behaves as what people have described as EV mode, with the only difference that I can't dissable it with a switch. the car is an 08 US model.
    has that happened to anyone? next thing will be to bring it back to the original stage.
  2. Keri
    Keri New Member
    65
    TEXAS
    out of my league. Did turning the car off and restarting it reset it?
  3. rpiereck
    rpiereck Regenerator
    289
    Very interesting, did you try redoing the procedure to see if the ICE works again?
  4. autovolume
    no I did not yet try. I have to admit I am a little concerned about not being able to set it back.
    if it doesn't work I was thinking of resetting to factory mode by disconnecting the battery.
    I will definitely go over the procedure in the morning.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Prius goes into and out of EV mode as it sees fit. The EV switch is just a request telling the control system that you would like to use EV mode if at all possible. In your case the conditions were appropriate for not using the ICE, so the car didn't use it. It has nothing to do with deactivating the seat belt beep.
    Tom
  6. bac
    bac Active Member
    863
    52
    Pennsylvania
    I'm assuming that you've tested it enough to tell if this is normal (re: Prius will do fully electric in certain situations) or if it really just won't kick out of fully electric mode. If that is the case, something is for sure wrong.
    Please keep the group informed! :)
    ... Brad
  7. Bob64
    1,540
    92
    Virginia
    Try some hard acceleration. That'll kick in the ICE.
