I need a place to do some work on my 2007
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Landon51, Feb 19, 2019.
  1. Landon51
    Landon51 Member
    190
    63
    US
    I'm looking for a drive way with access to electricity. Garage power is preferable to inside house power; however, I would certainly take what I could get. 8).
    I can be there on weekends or week days. Just whatever space you have, I'll
    I can bring cardboard, drop cloth, and I have a largish shallow "something"that I can use to place under my wheel as I work on it (no rust will hit your floors). I also have a small shop vac for any cleanup. I have all the tools that I need.
    With that said, you should know that I'm often wrong but never in doubt about anything. So I might be missing something; I just f don't know it.
    I know that I don't have Jack stands nor a floor jack, but those are nice-to-haves but not required.
    What I would need from you is a date, time , and address so I can show up and start working. I would need access to power in order to plug in an extension cord.
    Thank you all in advance.
    SFO likes this.
  2. oldtechaa
    oldtechaa Active Member
    336
    224
    NZ
    2013 Prius Alpha
    It might help if we knew what area you were looking in. I'm sure you're not going to drive across the country just to work on your Prius.
    Also, an interesting experiment would be using a storage unit with enough space for the car and power. I presume some storage units may have power...? I've never used one, so I've never looked in great detail.
    Mendel Leisk, edthefox5 and Skibob like this.
  3. padroo
    padroo Senior Member
    2,763
    2,252
    What kind of work do you want to do on your car?
    Skibob likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You might try @Rebound in Fremont and see what he is up to:).
    We’ve done a couple of meetups at his place there;).
    Good garage and lift(y).
  5. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    You already asked friends/family/coworkers?
    HomeDepot has a 2cycle gas generator for purchase $109. You'll have on demand portable power at your convenience, now.
    Home Depot has a 4cycle gas generator for rent. $44 for 4-hours, $63 for 24-hours.
    Consider:
    • commercial zoned area street parking
    • commercial shopping center (say a big parking lot of Home Depot, Walmart, etc)
    • residential area that doesn't have parking enforcement due to: time limit, parking permit requirement, or a street sweeping day.
  6. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Exactly! All I know is 53 and US. Not a lot to go on. What you want to do might be helpful also. People might be ok with a brake pad change but not an engine swap. Are you going to pay for this use? How much?
  7. Skibob
    2,912
    1,505
    Northern California
    No rust will hit your floors is more of an east coast thing. Not a lot of rust under the cars around Fremont. ;)
  8. Landon51
    Landon51 Member
    190
    63
    US
    Hrmn. I swear I had a paragraph saying that I live in Santa Clara, CA (San Fran Bay Area). And I'll be changing out a wheel bearing. All my tools are electric except for the ones that are 100% manual.
    Thanks in advance.
    #8 Landon51, Feb 20, 2019
  9. Landon51
    Landon51 Member
    190
    63
    US
    Thank you.
    Raytheeagle likes this.
  10. Landon51
    Landon51 Member
    190
    63
    US
    I've thought about both an air pump and generator. Santa Clara and most cities I've lived in have an ordinance about working on cars in the street.
  11. bisco
    51,937
    a portable carwash used to show up in our industrial park every sunday. nobody knew or cared
  12. padroo
    2,763
    2,252
    Have you ever changed a wheel bearing in a Prius. The bearing is usually seized to the knuckle. I took mine to an automotive machine shop with a ew bearing and had them swap them out. I don't have a press.
    Skibob likes this.
  13. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
  14. Skibob
    2,912
    1,505
    Northern California
    I wonder how much a used knuckle is? Seems like the fastest way would be to get a used one, replace the bearing then just swap it out.
  15. Landon51
    Landon51 Member
    190
    63
    US
    I've the full wheel bearing and hub assembly.
    Skibob likes this.
  16. Landon51
    Landon51 Member
    190
    63
    US
  17. padroo
    2,763
    2,252
    It's really not a big deal if you take it to a shop that has a press. I think they charged $25 for labor.
  18. Skibob
    2,912
    1,505
    Northern California
    True, but time is also a factor. If you have another knuckle already ready to go it makes the job a lot quicker. My neighbor has a press so it’s not a problem for me. ;)
  19. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    this dude shows up and injures himself you going to be looking at a big lawsuit or maybe this is the plan. sounds sketchy.
  20. Landon51
    Landon51 Member
    190
    63
    US
    Paranoid much? I'm sure that I can help knock out a no fault contract in less than 10 -15 l like I'm pp
