I need help
Discussion in 'Generation 1 Prius Discussion' started by RECORLY, Jan 28, 2014.
  1. RECORLY
    RECORLY New Member
    2001 Prius
    I have 2001 Prius and the engine light came on
    The manual says to take to the dealer
    I don't like dealers
    I have a 2001 Prius
    Engine light came on
    Owners manual says to take to the dealer
    Don't like dealers
    Any ideas what it can be wrong
  2. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Welcome! As with any vehicle, you can go to Autozone and have them scan the code for you. It will not give you Prius specific codes as to what they are or sub-codes but it will get you started. Is the car acting fine otherwise? We can not even start to help you without additional information or the codes.
    TomK
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    As TomK said above we need more information. Apart from the codes the cars millage/history, and your location as it is not in your avatar, all help us to help you.
    John (Britprius)
  4. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Doesn't sound you know much about cars, so I would find a mechanic you trust and has experience with hybrids. When the check engine light is on, there a laundry list is issues that can cause it to light up. It's usually not a simple DIY fix, unless your gas cap is loose.
  5. Britprius
    5,194
    1,922
    At the moment we do not even know what country he is in.
    John (Britprius)
