I Need opinion on Ride Quality with 17's
Discussion in 'Gen 2 Prius Accessories & Modifications' started by agron1979, Aug 13, 2007.
  1. agron1979
    agron1979 Junior Member
    28
    I want to get either 16 or 17 inch wheels for my gas sipper, but I want to know if the ride is going to get that much worse :mellow: The factory 15's look pathetic and I need to add some luxury/style even if I lose a few mpg...just need some opinions for the 16 inch as well as with the 17 inch wheel upgrades. I know it will handle significantly better, but all I want to know is if the ride quality will become really crappy :unsure: Thanks and I love this forum; just got tinted windows all the way around, shark fin antenna, and weather tech deflectors and will add pics soon B)
  2. robincx
    robincx "Fear is the mind killer"
    1,294
    North Boston, NY
    You have to do it. The 15's felt like balloon bicycle tires I hated the car in winds, it was very twitchy. I kept my stock wheels for snow tires. I put on a set of Scion tc wheels with Nexen 215's, and the ride instantly improved 200%. It tracks straight, sits solid and and looks pretty fine as well. You'll take a 10% hit on gas mileage, but it is well worth it - your mileage will start to go up again around 8,000 miles.
    Congratulations on your car, now pull the trigger.
    Oh, and grab a BT stiffening plate as well, it's subtle but an important mod.
  3. raymond.nieh
    raymond.nieh New Member
    It looks really nice with 17" with it, and I can imagine the improvement on traction.
    10% on MPG ... it can be worth it, if you push your car hard around the corner, otherwise compromise it with 16" will be more balancing.
  4. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    That's a sweet looking car; would look *really* great in white
    [laughing]
    Another suggestion for the OP: keep the tires and wheels and mod the suspension instead.
    Add the TRD parts and maybe a TOM's suspension brace or two; the car will feel lots tighter.
  5. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Generally, I hunger for cornering performance, but I also don't like spending money. My experience with my previous car with 17" tires is that, generally, they are significantly pricier than a comparable 15". There's also that initial investment for the wheels. With the low-profile sidewalls, it is easier to curb your wheels, if you're not careful. Potholes are the arch-nemesis for 17" wheels. They bend and get damaged easier. There's no question to the performance benefits, but the downsides are something to consider.
  6. agron1979
    28
    Thanks for all the help, but guys, how is the ride quality? Does is ride like crap with 17's or just a bit harder than the factory 15's? I am looking for style, but I don't want my baby to ride like crap where I can feel all the bumps and imperfections of the road :blink: Thanks again for all your help :D
  7. BT Tech
    BT Tech New Member
    885
    South Florida
    I installed a set of Scion 17" wheels/tires and have never looked back once!! Better handling and road feel but your gas milage will drop due to the added rolling resistance.
    Oh yeah, they look great too!! Welcome to the Prius "family"!!
    <div class='quotetop'>QUOTE(agron1979 @ Aug 13 2007, 06:37 PM) [snapback]495011[/snapback]</div>
  8. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(agron1979 @ Aug 13 2007, 06:58 PM) [snapback]495123[/snapback]</div>
    Well, the ride quality will suffer as you go up in wheel diameter. I swapped out the original 16s on my Touring edition for 15x6.5 forged wheels (Motegi) with 205/60-15 Michelin Pilot Exalto A/S tires. Add in the TOM'S front (upper and lower) and rear suspension braces and the car rides as good as it gets and cornering is like the wind. If someone doesn't know how to drive their car, and I am on a downhill section, I am running away from them. I have done this twice in the past week - once with a MINI and the second time with an E46 328i. Before the TOM'S braces, the car's handling was best described as wallowing - even the Touring edition.
  9. mtm
    mtm New Member
    Get the 17s!!! It handles much better but the ride is a little harsher but it looks a lot nicer!
