I need to confirm when the ECU would throw a code on a bad battery
Discussion in 'Gen 2 Prius Technical Discussion' started by JC91006, Jul 20, 2015.
  1. JC91006
    16,480
    8,397
    Can anyone confirm that the Prius would throw a DTC if the HV battery pack discrepancy is over .3 volts on all the modules?
    I've read this many times but is it a fact written somewhere?
    The examples I've seen when the car actually throws a code, the voltages are usually off by 1+ volts. Example all modules measuring 7.xx volts and one bad module that's low at 6.xx volts. That's like the examples I've seen when the car throws a code, not when it's only .3 volt difference.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    There are other things besides resting voltage that could make a Prius throw a HV battery pack DTC code.
    Are you currently experiencing a DTC?
  3. JC91006
    16,480
    8,397
    No, I'm not experiencing a DTC yet, but when I monitor the block voltages, I can see it jump to .3 volts difference.from max and minimum.
  4. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    JC,
    I'm sure you've read Art's "Predictive Failure Analysis" but here's the link anyway:
    Predictive battery failure analysis for the Prius Hybrid
    There is a "standard" min/max variation of .3v that gets thrown around here on PC and I think it's assumed this will throw up the triangle. I think it may, but I also think it has to be recorded by the hybrid battery ecu for an extended period. Of course I have no idea what that time period is but I'm quite sure min/max variation can and does vary at .3 and above on many, many batteries without any code or driveability issues. I believe 1.2 volts, or more, variation is the software's "instant triangle and rev up the fan" threshold.
    You can watch mini VCI while driving (somebody else driving, of course) and see these variations in older, yet still working fine, batteries. My daughter's 07 (151k) has been in the .3-.4 range for over a year now and runs as good as ever. I tested an 08 with 155k this spring and it showed real-time .4-.5 many times during the drive. The guy traded it on a 2015 but that car never even showed a check engine light in it's 155k life.
    It seems that many of the battery failures we see accompanied by snapshot data here on PC show the big variation of 1.2 or more. Thus my thinking that anything less than 1.2 can and does happen as we motor on in ignorant bliss. Art's article supports this, too. I'm with you though, watching any more than .2 variation wigs me out! My 2010 is still super tight, less than .2, thankfully. Now one of the resident electrical wizards can set me straight on all this.
    Mike..
    #4 m.wynn, Jul 20, 2015
    strawbrad and JC91006 like this.
  5. Patrick Wong
    18,200
    6,472
    The Toyota repair manual indicates that the conditions under which the traction battery ECU will log a DTC (P3011 - P3024, which corresponds to the 14 module pairs which might have an abnormal voltage) is Toyota intellectual property. However, the manual also goes on to say that if all module pair voltage differences are more than 0.3V, then replace the battery ECU. The test compares module pair 1 with 2, 3 with 4, 5 with 6, etc.
    I suppose the thinking is that if all of the module pair voltage measurements are so far off, then the ECU is more likely to be at fault than all 28 modules.
    The inference then, is that if one or two voltage differences between module pairs are greater than 0.3V, that the traction battery ECU may decide to declare a module pair at fault. However that is not specifically stated.
    JC91006 and m.wynn like this.
