I need to haul a 250lbs moped with my Prius gen 2
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Prius_shane, Mar 31, 2017.
  1. Prius_shane
    Prius_shane New Member
    Portland Oregon
    I have a 2004 Prius that I am buying a hitch for. I need to know if I am able to haul my moped (250lbs) on a motorcycle carrier 3000 miles.
    I don't have any money to buy a trailer but can buy a dolly or motorcycle carrier. If I go with a dolly, what would my max speed be able to be?
  2. Prius_shane
    Portland Oregon
    Also, I forgot to mention, my Prius has 227,000 miles on it. I am moving from Oregon to Michigan, too, if that makes a difference.
  3. William Redoubt
    William Redoubt Senior Member
    1,215
    1,164
    Coronado Island, California
    I don't think that would be a problem at all. That's about the weight of most fat chicks/guys. I assisted a friend of mine put a carrier for a Grom on a Gen 4. No issues. That's a harbor freight carrier (steel plate model, about $100) and a Curt hitch (about $115). We put a 1-1/4 inch to 2 inch adapter on the carrier after cutting a similar amount off the carrier main bar.
    m.wynn and Prius_shane like this.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Prius_shane likes this.
  5. Prius_shane
    Portland Oregon
    Nice! Thank you for the advice! CURT Manufacturing - CURT Class 1 Trailer Hitch #11468 someone is selling hitch near me for $80. Would this work as far as the hitch goes? If you have any photos of the process you and your friend did, I would love to see them! I'm a newbie when it comes to hitches. This will be my first time dealing with one. :)
  6. JC91006
    16,470
    8,383
    250lbs is like a fat mother in-law, just stick it in the hatch area
  7. William Redoubt
    1,215
    1,164
    Curt has a video on installing the hitch. It is not hard at all. I have installed two on Gen 4s.
  8. Prius_shane
    Portland Oregon
  9. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Please tell us more about this 250lb moped, does it have pedals?
    William Redoubt likes this.
  10. ktravelet
    ktravelet Junior Member
    Philaelphia, PA
    something like rubber spring inserts will help a lot with the squatting. You have to be riding low with that much weight on the hitch.
    Unfortunately I cant post links but google search:
    "Coil SumoSprings Custom Helper Springs for Coil Spring Suspension - Rear Axle
    Item # CSS-1168R"
  11. PA Prius
    PA Prius Active Member
    753
    240
    SE Pennsylvania
    Agree. That is one heavy moped. Also I'm wondering about your 3000 mile route from Oregon to Michigan. You may want to update your GPS maps! Depending on other luggage and passengers, have you considered draining the fluids and putting it inside?
