I NeEd YoUr HeLp!
Discussion in 'Generation 1 Prius Discussion' started by That_Prius_Car, Oct 21, 2009.
  1. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Well, I am in search of a used Prius, the only problem is, im on a budget D..=
    I am looking on getting a used 2001-2003 model, I just want a Gen1, an was told I could spend about $700 on one. Crazy, I know,
    but it has been done, one guy on youtube bought one for $450, and it was in really good shape! I will go with a salvage Prius if I have to, just can someone help me shop? I have wore my little hands out typing on this laptop trying to find a good deal = (
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Dreams are a wonderful thing! But keep looking, I hope you actually find something. When you do, you will have questions, start a list, we will be here.
    Good luck
  3. kenmce
    kenmce High Voltage Member
    1,531
    508
    NY
    I just want a Gen1
    The gen I is a nice little car.
    That is an unreasonably low price. You might get that price from a family member, or if it has 200,000 miles on it, or if there is extensive rust or body damage.
    There is more to the story.
    A salvage title will drop the price considerably.
  4. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    if you find them i will take 3 :)
  5. Patrick Wong
    18,200
    6,475
    Prius is generally the wrong car to buy as salvage (or for that matter, out of warranty) due to its unusually high electronics complexity. If something goes wrong and you can't DIY repair, forget it. Classic has several trouble areas including the transaxle, traction battery, inverter, MFD, etc etc. Dealer repair for those items will be in the low to mid 4 digits.
    With a budget of $700 you can buy a bicycle. Wait until your budget is $7K before you start thinking about buying an old Prius.
  6. bwilson4web
    15,528
    I used Ebay but paid $17,000 for one in 2005. Expect to pay $5-10k not counting your self-maintenance. I understand Craig's list works
    The maintenance manuals, used, are going for ~$150, for the minimum, two volume set. But buying any used car means you're going to have to fix stuff since the dealer labor rates are pretty stiff. That means metric tools, scanner, and the manuals. If you don't have a place to work on it, you're limited to nice weather repairs. Finally, you'll need a source of parts, either from the dealer or salvage and these can be few and far between.
    GOOD LUCK!
  7. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    $700 can get you a very decent folding bike to take it on mass transit. Very convenient and good for the earth.
    Seriously, you would have to be very lucky to get a Prius for $700 and find nothing wrong with it. If any major repair is needed later, it will probably cost you more than $700.
    It is a risky dream...
  8. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    Okay, I wasent able to find a Gen1 but I did find this, it is $3,500, and the man told me he would sell it to me for $2,900, its a Gen2. Here are some photos, and can you guys also tell me by looking at the car, if im getting a good deal? Thanks.
    Here are some facts about the car.
    2005 TOYOTA PRIUS BODY TYPE:MILES:TITLE TYPE:VIN #:pRICE:4 DOOR 132445 SALVAGE 907A CERTIFICATE JTDKB20U653052613 $3500 DESCRIPTION:RUNS AND DRIVES, REAR DAMAGE, GOOD AIRBAGS,AUTOMATIC TRANSMISSION
  9. Patrick Wong
    18,200
    6,475
    How can you believe that the car "runs and drives" if it has a flat RR tire? Further, the 12V battery definitely was munched.
    Unless you can do your own body work, I question why you would think this is a good deal. Looks like $6K worth of body work, at least. Who knows if the rear axle and suspension were damaged.
    With a salvage certificate that car won't be worth much if/when you are ready to sell it.
  10. KK6PD
    4,003
    944
    118
    OK, it looks like most of the damage is in the Right Rear. The 12v battey is located there, I would guess it's toast, REPLACE THAT! Next is the body work. The Right Rear Quarter Panel needs REPLACING, the Rear End, NEEDS REPLACING. The Hatchback may be OK, it's hard to see in the photo. Most of the damage looks to be body related. If you could find another '08 at a pick-a-part you could pull the body panels you need and come up with a chance of success.
    That being said, on the other hand, there must be some sustantial damage for the insurance company to total the car and salvage it. Depending on what model, you have a price range of 25k to 30k new, its 16 months old, or so, there has to be some MAJOR damage that exceeded the insurance companys limits, so it was salvaged. I am betting FRAME DAMAGE, and if thats the case, it will never run true.
    Anybody else have any ideas to help out???? Step up to the plate!
  11. bwilson4web
    15,528
    1. Where is it relative to where you are?
    2. How will you get it back to where you live?
    3. What sort of work area do you have to work on it?
    4. Do you have budget for maintenance manuals, body manual?
    5. Do you have tools?
    6. What have you done with a car in terms of similar repairs in the past?
    If you think you are ready for a long project, go for it. It won't be cheap but it will be interesting.
