I own a '14 gen 3 94k miles. Both low beam head lamps Abruptly Stopped working.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hayesr89!, Dec 18, 2017.
  1. Hayesr89!
    Hayesr89! New Member
    South Carolina
    My fog lamps, running lights, and high beams all function normally. I just noticed this and have not had time to check the fuse box yet. I am new to Gen 3 so i thought i would ask a little guidance.
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Check you fuses and check your bulbs.
    NutzAboutBolts likes this.
    49,455
    is there a relay?
  4. Sippy Theut
    Sippy Theut New Member
    Virginia
    My 11 repeatedly had both headlights go out at the same time. I was putting in non-OEM bulbs. Using OEM did the trick. Mine would go out in bad weather.
