I Phone 4s Will not stream Bluetooth media audio in Prius V.
Discussion in 'Gen 3 Prius Audio and Electronics' started by Christopher Neglia, Oct 10, 2012.
  1. Christopher Neglia
    Christopher Neglia Junior Member
    Jacksonville, Florida
    I just had a major let down! The Iphone 4s is not compatible with audio bluetooth streaming in my Prius V. I called toyota support and they sent me to Toyota.com - Connect, on the site it will ask you your phone model and car info, then it lists all the capabilities of you phone connections with green check marks and red X's. Damn technology, what a bummer.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Do you have a IV or a V as your model? Your profile says five, which doesn't make sense for 2010 since models were Roman numerals that year only.
    I just got my first iPhone, a 5, but yeah seems the iPhone operates differently than android in some ways and even the 4 is different than the 5 iPhone wise...
  3. Christopher Neglia
    I have a 5 i dont know why i put IV
  4. Christopher Neglia
    does the I5 work ?
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    If you have a 2010 you have a V (uppercase) not a five, that was kinda what I was trying to point out. Roman numerals were used for model designation in 2010. After that, 2011/12 etc they went with two, three, four and five...
    And yes, my iPhone 5 in my 2012 does stream music over Bluetooth. Not sure if the iPhone 5 does in a 2010/11 though.
  6. Christopher Neglia
    I know this... V/5 all the same to me. When u put V people tend to think your talking about that wagon.
  7. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Uhm, ok lol, as long as you know you have a V.
  8. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Not sure how older model Prius work but with Prius 2012 and the 6" display, if you get the Hotspot option from your cell provider the iPhone will work via Bluetooth. Toyota will tell it will not work but it does...again on 2012 6".
  9. Christopher Neglia
    I own a 2010. I'm guessing the software is not compatible with the Iphone 4s.
    My droid worked just fine.
  10. ProximalSuns
    1,877
    PNW
    Bluetooth is Bluetooth. My 2009 Escape Hybrid worked with iPhone as does my 2012 Prius as phone and music source via Bluetooth.
  11. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Yeah, when I had a 2010 V before my 2012 PiP, my htc evo worked fine streaming audio over BT in it as well.
  12. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    No all bluetooth is not the same. To stream music in stereo you need an enhanced version of bluetooth.
  13. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    OP, do you have the 2010 Prius V with any navigation system (via nav, solar roof or advanced technology package)? From looking at Toyota Vehicles : Toyota Announces Prices for 2010 Prius / Toyota, it looks like you need to have nav via ones of those means to have Bluetooth music streaming (aka A2DP music streaming).
    No factory nav == no music streaming.
  14. Christopher Neglia
    If anyone has a 2010 Prius V please let me know if you can figure out a way to solve this problem.
  15. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    See my earlier post. It's dependent on you having nav on the 2010-2011 Priuses. Do you have it?
  16. Christopher Neglia
    Yes I do have the nav system. I thought all Prius V(5)'s came fully loaded. except sunroof option.
  17. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    No, in 2010 on a Prius V nav was still optional either alone or included as part of the adv tech pkg.
    2010 Prius Models and Option Packages | PriusChat
  18. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Judging by the table, I don't think so.
    It should work though. When I still had my iPhone 3G, I did A2DP music streaming just fine w/2010 Lexus HS 250h (w/nav) that I won a week test drive of. The nav system is of roughly the same generation and quite similar to what's in 2010-2011 Priuses except that the Lexus didn't use a touchscreen and had a mouse-like controller w/haptic feedback.
    You might have to pair the phone 2x (or in two different areas). My memory is foggy as I had the car for a week around Thanksgiving 2009.
  19. Christopher Neglia
    I think i'm going to go to the dealership tomorrow to see if they can get it to work.
  20. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Try
    first.
    You'll may need to go to Settings > Bluetooth on your phone before/while doing this.
    Christopher Neglia likes this.
