I reconditioned my hybrid battery - by accident
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Matt98svt, Dec 3, 2024.
  1. Matt98svt
    Matt98svt Junior Member
    81
    South Carolina
    2015 Prius v wagon
    I have a 2013 with 205k on the original hybrid battery. It still does really well averaging 45mpg but i have noticed when I get in line at a fast food restaurant or sit in the car with the air on the battery drains quite quickly, in fact much much quicker than it used to just a year ago and the engine cuts on to recharge things. Never have had any battery codes though. I purchased a prolong hybrid charger but have not had time to use it just yet. Long story short I borrowed my fathers truck to go out of state to pick up some speakers and let him drive my prius in return. He got home from church at 12:30pm and thought he had turned it off but left the car running on the carport until I got there about 7:30pm. I know people car camp all the time but my car has never sat running like that before. When I got in it the battery gauge showed the hybrid battery was fully charged vs usually the motor only runs to recharge the battery until its charged up 2-3bars and it cuts off and runs off the battery again. I felt sure the battery was now messed up in some fashion and I would soon get a code.I also wondered if possibly the gauge was somehow messed up as it now shows pretty much fully charged or just 1-2 bar down when it used to go all the way down. Its been like this about a week though and going though the drive though this morning it barely used much battery at all and the engine did not cut on once. I have not connected the car to techstream or run a dr prius test yet (hopefully this weekend) but letting the car run for half a day certainly did something to the battery.
  2. qmanqman
    qmanqman Active Member
    439
    152
    CO
    That's awesome
    Matt98svt likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,115
    5,316
    Pacific Northwest, USA
    This indicates that your battery pack will be much improved once you use the prolong system. A really long drive, as well as a leaving it running for a long time will create a slight boost to pack performance, but not much compared to how much the Prolong system will change things.
  4. ASRDogman
    ASRDogman Senior Member
    7,846
    3,998
    It doesn't sound correct. Of all the times I've sat, It has never gone beyond 3 bars, or
    below 2 bars. Until the end of it's life.
    Take the time to install the harness for the Prolong system, It's not hard, just takes time.
    And clean all the bus bars with backing soda and water. And a wire brush.
    Be VERY careful with the posts on the battery packs, you can EASILY short two together!
    You only want to touch ONE post at a time.
    It will take 3 days to complete the full cycle. If you watch it closely and often, you can catch it
    when it finishes the discharge cycle and get it on the charge cycle.
    The 4th, and last charge cycle should take the longest. When the voltage full and stable, let it charge
    for another 2 hours. So it will have a chance to fully charge each block, and "balance" all the blocks.
    Wait 2 or 3 hours after the last charge for the battery to cool off and for the voltage to go down and
    get stable.
    It will be well worth it! It kept mine going to 2.5 years and about 100,000 miles.
    Then I got the lithium pack, then the Sodium pack! That is well worth it!
  5. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    2 bar minimum is fine but 1, squirrel!
  6. Matt98svt
    81
    South Carolina
    2015 Prius v wagon
    Drove the car a good bit today and battery still holding up much the same keeping a strong charge even when sitting in line, how long it will last i do not know. Already installed the prolong cable as well as new bus bars (old ones were pretty corroded) and hopefully in the next couple of weeks will have the time to do the reconditioning. Too much on my plate lately. Between taking care of my granddaughter, looking after and taking meals to my parents mid-80s, picking up hours at the hospital, and other projects just haven't had the time yet as well as our garage has been tied up with another prius project. Bought a 2012 V w/ 169k for my wife a few weeks ago for $2000 that needed the head gasket done. Beautiful car inside and out and averaged 54.9mpg driving back from the other side of atlanta, 180miles away. Head gasket took me about a week and a half working on it an hour here and an hour there when I had free time but overall was pretty easy with the help of members here and youtube vids (hope to do a post on this very soon and share a few things I have not seen that helped me greatly). Anyhow, I will try to run a Dr Prius battery test this weekend on my cars hybrid battery. The last two I did ended early as the battery would die and engine would start to recharge the battery before the test was over and would say error but read 62 percent if I recall. I reached out to the people at dr prius and they said even with the error code that score should be 62%.
    Here is a pic of my wifes new 2012 V and of my bus bars
    ASRDogman likes this.
  7. PriusCamper
    13,115
    5,316
    If you ever notice a sudden drop down to one or two charge bars that then recover back to normal charge in 5 to 10 minutes, that's due to the corrosion in the bus bars working their way into the battery ECU via voltage sensor wires. So if that happens you'll want to open the ECU and clean it up inside there. You can also buy new higher quality voltage sensor wire harness at acenbay.com
  8. mlsimmons
    mlsimmons Junior Member
    24
    Everett, Wa
    I am in the process of installing a new set of NewPriusBatteries into a spare battery assembly for a Gen2 Prius - when I removed the factory harness plug for the voltage sensor wires from the ECU I noticed some green corrosion on a few of the pins in the ECU - any recommendation on a safe way to clean them off? Those pins look awfully fradgile
  9. ASRDogman
    7,846
    3,998
    Glad you got the harness installed. The rest is easy. Even if you just charged it overnight
    it will peak them out, and that will help. Those bus bars don't look bad. It's the copper that's
    important, not the black coating...
  10. ASRDogman
    7,846
    3,998
    Electrical contact cleaner spray. Spray both pieces and attach and remove the a few times.
    That's the safest way. There are very small brushes designed to clean the small pins.
  11. Mendel Leisk
    41,957
    That would be much appreciated. (y)
    PriusCamper likes this.
  12. PriusCamper
    13,115
    5,316
    I use a tiny piece of sandpaper with a screwidriver behind it... I've also used an emory board.
    Most important is to open up the inside of the ECU and clean the corrosion off the other ends of those pins where they connect to the circuit board.
  13. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    The hv bat stops charging at 60% and begin charging At 40% with I.c.e. 99% of the time even as it idled then a lot of prolong charging people are pounding the sand w both fists.
  14. StarCaller
    StarCaller Senior Member
    1,280
    732
    Cedar Crest, NM, USA
    • The hybrid battery (HV battery) typically operates in a range of 40%-80% state of charge (SOC) to optimize battery life and performance.
    • The internal combustion engine (ICE) or regenerative braking charges the HV battery when the SOC drops below approximately 40%.
    • Charging usually slows or stops when the SOC reaches around 60%-70% during normal driving conditions. However, the car may let the SOC rise higher (up to ~80%) under certain conditions, like long downhill drives.
    So, while 60% and 40% are within the expected operating range, the system is more dynamic, and exact thresholds can vary slightly depending on driving conditions.
    Brian1954 likes this.
  15. Mendel Leisk
    41,957
    Maybe 60% is when all but the top two pips are lit (usual peak charge), and 80% is when those two top pips light (say on an extra long downhill).
  16. StarCaller
    1,280
    732
    • "Usual Peak Charge" (60%): This corresponds to when all but the top two pips are lit on the battery display. It reflects the target range the system tries to maintain during normal driving for efficiency and longevity.
    • "80% SOC on Long Downhills": This occurs when the top two pips light up, which is rare and typically happens during extended regenerative braking (like on long downhill stretches). This reflects the system temporarily storing more energy.
    In summary, the battery display provides a simplified representation of SOC. The top two pips lighting up doesn't mean the battery is fully charged; it indicates it's nearing the upper end of its operating range (about 80%).
    burebista, Mendel Leisk and Brian1954 like this.
  17. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    You bought the reconditioner hv battery kit for the original nimh battery pack, and your now on a second battery pack but yet it was worth it? Definitely doesn’t compute.
  18. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    OPster hv battery went thru that process so for sure his hv bat didn’t go through ey a reconditioning process.
  19. rjparker
    rjparker Tu Humilde Sirviente
    10,588
    6,641
    Texas Hill Country
    Translated: The oem was worn out but limped on with or without the Prolong. Then the aftermarket lithium pack was great (as seen on Priuschat) until it was not. It was replaced two or three years later with another experiment that may or may not work in freezing weather. Plus the experiments cost as much as a new oem that will easily run ten or more years.
    #19 rjparker, Dec 9, 2024
  20. ASRDogman
    7,846
    3,998
    No, you didn't read everything....
    I used the Prolong system for about 2.5 years. Well worth it.
    I was going to put in the battery from Toyota, all new cells. But they won't sell
    it to anyone unless they are hybrid certified.
    So I looked for new ones from someone else, but they were way too expensive.
    So I looked for the round cylinders, again, too expensive. And I guess he had gotten
    burned enough to be pissed off that he warranty basically said you get nothing unless
    you follow a hundred rules..... So I said no.
    That's why I decided to go with Jack and the lithium. I had no issues with ordering and
    it arrived in 3 days.
    I was very happy with it, and him.
    It was about 4 months, not sure exactly, before Jack contacted me.
    He asked me if I'd interested in testing his sodium pack, and I said yes.
    I had already been researching the sodium batteries before knew he was working
    with the sodium cells. So I said yes.
    It's even better than the lithium. At least for me. A lot lighter and easier to lift into the car.
    MPG has improved and distance is better. 104 degrees is the highest the battery has
    gotten, and that is when I was trying to get it hot by sitting in the hot humid sun for half the day then
    driving without letting the engine kick in. It was in the mid 90's for several months here with
    super high humidity here.....
    Jack has been great. Getting back with me quickly with all the questions I had.
    I would recommend it for anyone who needs a new hybrid battery.
