I replaced the hybrid battery, now the traction control, ABS, and emergency brake light are all on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nathan Renner, Apr 9, 2018.
  1. Nathan Renner
    Nathan Renner New Member
    Sonora
    The title pretty well sums it up. At 188,000 miles my dashboard lit-up like a Christmas tree. I ran the codes and they indicated I needed a new hybrid battery. I replaced it with a new from the dealer battery. The car now runs but the traction control, ABS, and emergency brake light are all on. I had a friend reset the lights and the came right back on. The are not always on. Sometimes they are on when the car starts and stay on. Other times the come on and then go off. Any suggestions would be much appreciated.
    #1 Nathan Renner, Apr 9, 2018
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    you need go read the codes
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Who did the installation? Although unrelated, what were the costs?
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    I agree with @tankyuong. If the brake fluid is OK, you need to read the codes to start the troubleshooting. There are several possibilities.
    Raytheeagle likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    NO.
    First you need to test the 12 V battery.
    Because if it is weak it can cause false codes to be set.......including ones indicating that you need a new hybrid battery sometimes. :eek:
    After that, you read the codes and chase what problems are left.
    But.....unless you have experience working on ABS brakes with stability controls, that work is probably best left to a professional. Except maybe for checking the level of brake fluid.
    How long since the brakes were inspected and fluid changed ??
    The recommendation often is 2 years.
  6. Mendel Leisk
    38,652
    I'm guessing from his wording, and the subsequent DIY reaction to the trouble lights, that he did it himself. If so: the cows have escaped the barn, but anyway: for this, I'd be inclined to pony up for dealership to do the install, just to get:
    1. 3 year warranty.
    2. no core charge.
    3. no ambiguity as to what constitutes a "core".
    4. no ambiguity if there's a problem, no fingerpointing, it's up to the dealership to rectify.
    The US schedule, for complete brake inspection, is 36 months or 30K miles (as opposed to the visual inspection, at every service interval): on page 41 of the US Warranty and Maintenance Guide.
    Toyota USA is deathly silent on the subject of brake fluid change; apparently in the US there's a miracle brake fluid (comes from the same place as the lifetime transaxle fluid?). Since maybe 2012, Toyota Canada's been saying to change it every 3 years or 48K km's, on all their vehicles.
    #6 Mendel Leisk, Apr 10, 2018
  7. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Well was he scared off? No update since April or activity since his first post.
  8. Mendel Leisk
    38,652
    iskoos likes this.
  9. iskoos
    iskoos Active Member
    401
    246
    Orlando, FL
    He must have solved this problem.
    However updating us wasn't in his list. "Too bad" as Mendel states.
  10. bisco
    49,393
    one post wonder
  11. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    I did measure my 12v battery today before starting and it was at 12.6 . That good? Still the original battery
  12. bisco
    49,393
    that is very good.
    DaneH5 and Mendel Leisk like this.
  13. iskoos
    401
    246
    Orlando, FL
    As Bisco said, 12.6 volts standing voltage (especially some hours later) is very good and normally don't indicate any problem. My 8-year-old Prius battery was showing 12.5volts most of the time (even hours after being shut off). But then it failed without a warning one day. I was able to drive it back home and when I measured it, it was still showing 12.5 something. But as soon as I turned the headlights on, the voltage took a dive. The battery was gone.
    On my other (non-hybrid) car, I also monitor the battery voltage. I am getting around 12.5volts right after engine shut down and it goes down to 12.3volts level over-night. However the voltage doesn't dip when put under load. It has been like that since 2015. It isn't on its best days but still has some life in it.
    What I am trying to say is that voltage could be a good initial indication but the best is the load test.
  14. Mendel Leisk
    38,652
    Yes: voltage is like the tip of the iceberg. Especially if the car's just freshly driven or charged it'll read optimistically high voltage. Electronic load testing (not the old school "toaster" load tester) is the way to go, and there are DIY level testers, around $50~100. I use a Solar BA5, works a charm.
  15. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Good point , I need to look under a load.
