I see a flaw with the stiffeners
Discussion in 'Gen 2 Prius Accessories & Modifications' started by krazyglue, Dec 12, 2005.
  1. krazyglue
    krazyglue New Member
    Seattle, Wa.
    I have been a lurker here for a while and i think something needs to be said before some damage is done.
    The BT stiffener the one made from 6061-t6 should not be installed
    This is basic engineering an aluminum plate in contact with a piece of steel rubbing though the .002 (thousands of an inch) of anodizing will make a spot for galvanic corriosion to start.
    Aluminum in contact with steel (the prius frame), makes an anode and a cathode add an electrolyte (rain water, or even better yet road salt)and you have a battery....... even if it is anodized its still aluminium oxide and the same result will happen.
    It will not happen over night, but give it 2 maybe 3 winters and the contact area may be comprimised.
    anyone with basic chemistry or engineering can see this.
    Make it from mild steel and powdercoat it, that would be a quality product.
  2. BT Tech
    BT Tech New Member
    885
    South Florida
    The BT Tech Prius Stiffening plates are made from billet 6061-T6 and are type 3 hard anodized and bolts to the frame using stainless steel M8 bolts that are recessed in our plate. As you know hard coating anodizing is an EXTREMELY strong scratch resistant method of protecting aluminum. The Rockwell hardness of our hard anodized finish is between 62-70 vs. less than 30 for a powder coated finish.
    Using mild steel with powder coating is NOT a material I would chose to work with. Powder coating could rub off leaving the mild steel unprotected and will start to rust immediately. In addition to the poor corrosion resistance, mild steel is approximately 3 times heavier than 6061-T6.
    Anodizing is critical to the aerospace industry. The aerospace industry and the military use mainly hard coat anodizing because it renders the aluminum extremely hard (60-70 Rockwell C), heat resistant, provides corrosion resistance of 336+ hours per ASTM B117, and it provides electrical insulation of 800v/mil thickness. Hard anodizing also yields a product resistant to harsh weather, salt sprays and abrasive machining processes.
    Aluminum processed by hard anodizing can be only a few points away from the hardness of diamonds.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    I'm glad you've stopped lurking, krazyglue. Now we know who you are.
    The BT Tech plate makes a world of difference in the handling of my Prius. With the hard anodized finish, I'll chance it turning into a bigger battery then the HV one.
    Do you have a Prius? Thought not.
    What are your engineering credentials?
  4. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    krazyglue,
    That's a valid concern, but you might have phrased in such a way that you weren't suggesting that BT Tech was clueless. Clearly Brian had good reasons for not doing what you suggested. It's good to see that he had is reasons and stated them. Now everyone has a better understanding (at least I do) so in that sense it was a good post.
  5. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    Actually, I raised the same question in another similar thread.
    I am more concerned about the other party of contact, the Prius body frame. I would feel much better if another layer of antirust coating is spreyed on the contact area after installation to seal the contact in. :)
    Thanks for BT Tech's answer. I learned a lot about anodizing aluminum. I surely will find more read about it thru google.
  6. krazyglue
    Seattle, Wa.
    You still have not answered what will happen when rainwater comes in contact with steel and aluminum, it does not matter that it is hard anodized, hard anodizing is aluminum oxide bult up on the surface. You will have water in contact with 2 dis-similar metals.
    I am not saying the product doenst not reduce sway or better handling (dont have an opinion here), i am saying that in a few years you will have corrosion on the frames of your prius's in the imediate contact area of the plate.
    I little backround on myself, i have been a maufacturing engineer for 10 years, before that i was a cnc machinist/programer. My work was doing heavy aircraft overhaul/rework, cargo conversions. Now i design medical istruments.
  7. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I think that's a valid point, although even if the paint and the coating on the stiffener were to wear through I think it would take a long time to cause damage. Then again, I don't live where roads get salted.
    I should be getting my stiffener any day, it's in transit. Just to add another layer of protection when installing it I'll add some .015" mylar between the two mating surfaces.
  8. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    What if a couple of rubber washers were used in attaching it?
  9. Wynder
    Wynder New Member
    254
    Bear, Delaware
    I'd think rubber can deteriorate with the weather as well -- the mylar sounds like a nifty idea.
  10. BT Tech
    BT Tech New Member
    885
    South Florida
    You are speaking of galvanic corrosion and this would only start to occur if BARE aluminum is contacting BARE steel. What I have explained is that we are not using uncoated aluminum but HARD anodizing.
    We are not the first company in history to use an aluminum plate that is hard anodized to connect to a steel frame. This has been done for years and your concern though valid in theory is actually of very little concern in real world situations.
    Obviously you have not seen how our plate is mounted to the vehicle. The top of the plate that attaches with 2 M8 stainless bolts on each side is practically sealing the top of the frame. If rain water or anything else for that matter were to penetrate this area this still would not be an issues as the plate is hard anodized and non conductive.
    I suppose if someone was very concerned one could always attach a sacrificial zinc anode to the plate but this IMO is not required.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  11. richard schumacher
    7,663
    1,038
    United States
    krazyglue, are you saying that the hard anodization will be broken or penetrated at the points of contact?
  12. chrisek
    chrisek geek
    94
    Carson City, NV
    Brian rocks! :D
  13. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    This is what I was going to suggest if someone was overly concerned. All big steel bridges have a huge chunk of zinc buried in the ground at on or the other end just for this purpose. I also don't think it's quite necessary in this situation.
  14. slipperytoast
    slipperytoast Junior Member
    Brooklyn, NY
    I just picked up my Prius from the garage where they installed the BT stiffener. The mechanics were really excited to see a Prius and invited me to see the installed stiffener while the car's on the lift. The fit and finish of where the plate meets the chassis looked tight so I'm inclined to take BT Brian's assurance on that. And driving home I noticed the improved handling right away, (part of it is probably psychological). All in all it's a nice mod!
  15. 200Volts
    200Volts Member
    429
    43
    Northern CA
    My aluminum parts on my hot engine (block, heads, etc) have steel bolts, steel exhaust, steel oil pan, steel brackets, zinc washers attached and operate about at about 250 degrees. Most aluminum parts elswhere are attached with steel bolts. My aluminum motor-generator is attached to steel bolts and brackets.
    All with no rust, even at elevated temperatures.
    So, I would not worry about the BT Tech plate to chassis interface.
    200Volts
    B.S. Chemical Engineering (anyone want to discuss EMF?)
  16. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    First, my credentials -- I failed chemistry in college.
    Second, a thought -- Doesn't a conductive element, in this case, water need to be present for galvanaic action to occur? Wouldn't the elevated temperatures evaporate any moisture thus prevent the effect?
    Third -- Fools rush in where angels fear to tread. :p
  17. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Yep and keep an eye on it and replace as needed. Boats in salt water do it. hgas boy chemist. BS Chemistry The dean is still trying to figure out the exploding toilet seat with bronzed butt. I stand by all previous statements "I know nothing".
    One of the things I learned growing up in Ohio is that with enough salt and water and time you will corrode almost anything, the question then becomes how much time salt and water? Will you have sold the car to someone else? ;)
  18. DocVijay
    1,455
    Tampa, FL
    Well, I only have a minor in chemistry, but I think I know enough to say that it's very unlikely to be a problem to anyone here.
    A boat is usually immersed in salt water all the time. A bridge is usually made of iron. THe zinc node is there mainly to prevent rust. The zinc corrodes before the iron does. I highly doubt that anyones Prius will be in the kind of environment where this could be a problem. If it is, there are a multitude of other components that would corrode just as fast or even faster and would cause major problems.
    What it comes down tois if you're scared of the potential for the reaction, DON'T BUY ONE! If you're not, then do. It's that simple. I doubt it will ever be a problem, and so I ordered a brace.
  19. johnnieliu
    johnnieliu New Member
    60
    PNW
    Why can't one just put some sealant between the stiffener and the frame? I realize that the AL is anodized, but doesn't hurt to add sealant between the 2 parts.
  20. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I thought that was my point?! B)
