i shorted my 12v battery while driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by whoz_thatdude, Aug 16, 2022.
Tags:
  1. whoz_thatdude
    whoz_thatdude New Member
    yomammashouse
    my battery was not covered and a metal item in my trunk shorted the 12v battery when i made a left turn killing the car completly while driving
    nothing works now except a cargo light in the trunk
    i need the location and part description of whatever fuses i have likely blown
  2. whoz_thatdude
    yomammashouse
    this is for a 2010 prius base model hybrid
  3. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    Just go under the hood fuse box and take a look at all your fuses and then take a look on the battery positive terminal there's a little fuse to think of five or seven amp in that positive battery terminal affair and there may be a fusible link back there Not sure about that so do you see anything burnt on the top terminal of the battery The positive then check both your fuse boxes The one in the car and the one out when the metal bar ran across the terminal so it ran across the positive to the body how long was it there did it burn or weld the piece of metal did it melt it any pictures it depends how bad it was you might have just blown a fuse or two do you see any wires burnt coming off the positive terminal?
  4. Tombukt2
    12,214
    2,155
    Durham NC
    I don't have the back end in my car at all My spare tire will has tools in it no spare tire so when I whip around the corner right smartly everything is sitting in the spare tire well that can't roll across the battery The only thing I'll allowed to be level with the battery or above is wood and things like non-combustible items non-metallic plastic etc
  5. ChapmanF
    17,347
    A 2010 does not have the little 5 amp fuse at the positive battery terminal. That's a Gen 1 and 2 thing. There is a 140 amp fuse there. You don't necessarily see it: the positive clamp thingy kind of drapes over the side of the battery like something in a Dalí painting, and the "fuse" is the part that drapes over.
    Gen 3 also has a 125 amp fuse pretty well buried in the front fuse box; there are some threads here with pictures of how you can get a glimpse of it and get to it. There's also a post somewhere in which I showed some easy-to-reach test points you can use with your meter to check the continuity of that fuse without much hassle.
    #5 ChapmanF, Aug 17, 2022
  6. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    Darwin Award? ;)
    Grit, Krall and Doug McC like this.
  7. Tombukt2
    12,214
    2,155
    Durham NC
    Yep forgot this was like Mom's car 2010 and not my '09 duh
  8. whoz_thatdude
    yomammashouse
    yeah im almost as stupid as the engineer that put the battery in the trunk and not under the hood where god intended
  9. whoz_thatdude
    yomammashouse
    the main 140amp battery fuse at the positive terminal is ok i must have blown up something else
  10. whoz_thatdude
    yomammashouse
    nothing looks burned cables are ok
    #10 whoz_thatdude, Aug 17, 2022
  11. ChapmanF
    17,347
    Posted by the person it happened to ⇒ does not qualify.
    StarCaller likes this.
  12. whoz_thatdude
    yomammashouse
    checked the fuse boxes under the hood and dash and i do not see anything wrong.
    battery terminal fuse is fine also.
    battery has 11 volts in it
    i have a good key but when i push the brake it says key not detected
    key also does not lock/unlock doors
    #12 whoz_thatdude, Aug 17, 2022
  13. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    11 volts does not mean that you have a good battery. Do you have a charger?
    If I didn't have a cover over my battery, I'd at least wrap up the positive terminal with a non-conducting rag or something to prevent a short like you had.
  14. bisco
    51,155
    11 volts isn't gonna cut it. o get it charged up and load tested and replace if necessary.
    test your fob battery as well
  15. whoz_thatdude
    yomammashouse
    i used a battery booster but it still wont start
  16. bisco
    51,155
    disconnect the 12v neg, and try the booster pack. are you sure the pack is good?
  17. whoz_thatdude
    yomammashouse
    i was able to jump it using a car battery i believe i just need a battery now
  18. whoz_thatdude
    yomammashouse
    im letting it run for a bit to charge
  19. whoz_thatdude
    yomammashouse
    it seems that the short killed my battery and not the car i will get a new one if it does not charge
    thanks all
    except that guy who said darwin award he wasn't very helpful
  20. StarCaller
    1,271
    723
    thanks for the honorable mention / ;)
    Grit likes this.
