I Stretched My Bladder!! (i think)
Discussion in 'Gen 2 Prius Fuel Economy' started by DaveinOlyWA, Aug 14, 2004.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i went to the gas station today filled with anticipation since my computer mileage was at 56.5 mpg. i figured for sure that this would be the 3rd consecutive tank in a row with increased mpg.
    but the "pump" mileage worked out to only 52.2 mpg!!! that is 4.2 mpg below the computer. i was astounded.
    so i started to think why this had happened. i think that i basically have filled up to a fuller tank than i have before. the reason i think this is that i was unfortunate enough to choose a pump that had a messed up seal on it. so when i filled up, it pumped only the first 2 gallons or so in and then it kept shutting off. i could then only put gas in in 10-20 cent increments. ( a major pain in the A#@!!) this made it difficult to determine where full was since i couldnt even keep the pump going at the lowest speed either.
    i stopped at the nearest dollar after i got to the point where i could only put in a nickel or so at a time. so i guess, im going to have to wait until i fill up again to really figure out where my mileage stands.
    but the pump mileage is only .7 mpg below my lifetime average. but it does make the lifetime difference from the computer verses pump average to 1.5 mpg. because of lower gas prices ($1.839) i set record for lowest cost at 3.34 cpm
    but i was surprized at how difficult it was to put gas in when the seal was screwed up. no matter how hard i pushed the nozzle in, it didnt do any good. this is also the first time i actually could smell gas when fueling my Prius. so i guess i poluted even though i didnt spill anything... :|
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    I have had the same thing happen 3 times so far, and I think that the bladder has expanded a bit each time. We'll have to see if it shrinks back when it starts getting colder, but for now, each time I've seen the fill increase, the added capacity has stuck around for subsequent fills.
    Originally I was lucky to get 6-7 gallons in on one fuel gauge bar, now it's up to just about 9 gallons.
    I'm getting confused on the Tank Filler Flap/Seal issue. Are there different Tank Filler configurations in the CARB versus Non-CARB states or something? Part of PZEV?
    I'm non-CARB. My Tank Filler Neck has what looks like a black rubber washer/gasket right inside the fill hole. It seals very firmly around the Fuel Nozzle. I have to almost force the Fuel Nozzle in.
    I am not aware of any flap anywhere. It does seem to block all fumes, and does seem to increase back-pressure resulting in premature nozzle shut off.
    Based on what people have said here, particularly those who have had tanks replaced, I'm wondering if there are multiple configurations for this.
    As an aside, when I read the topic of this post, my first thought was that you had taken a road trip and driven an entire tank without stopping. I wasn't sure I really wanted to know that much info about your 'bladder' :)
  3. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well i have seen two kinds of gaskets. there is the flexible hose that is large enough to cover the entire filler tube.
    unfortunately, the one i had problems with is the thicker donut shaped one that seems to be filled with soft foam. it is the same size as the outside and can be difficult to seal well. the one i had the donut was crushed on one side and torn away from the nozzle a bit.
    as far as capacity, i dont run the tank that low to be honest with ya. the most ive gotten on a tank was 470 miles but i had 2 bars left. (ive never seen it down to one bar)
    but as i said, i'll just have to see how the next tank looks to get a good idea of things. when doing the fill the tank up even in a regular car, you will have variances that will fluctuate your mileage a ½ mpg or so. i really only look at tankfulls to see if any trends are developing. the only thing i really take to heart is the lifetime mileage. (the more gallons and miles you add up, the smaller the error in your calculations become)
  4. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    My fillups are usually over 11 gallons and several times over 11.5 gallons. I am currently at 58.0 MPG with 397 miles on the tank. This could be my 700 mile tank but looks like I need to up the average a bit.
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok i have an update.
    it now appears that my bladder did not stretch. i simply used a gas pump that ripped me off.
    i have come to rely on the mpg reading on the computer more than the "pump" mpg simply because its an established fact that 11% of pumps in WA st are inaccurate. (the nationwide average is expected to be about the same as the inaccuracies is the result of physical deterioration of a metering value in the gas pump. the only way to avoid this possibility is to only use pumps that have been inspected recently. that is something that i am beginning to find out is not possible where i live.)
    i was going to use the same pump 3 times in a row to eliminate variations in fill amounts, but after two times in a row where the pump average was way below the computer average i decided i was tired of giving away my money.
    i have since reported the pump to the dept of weights and measures and they said it will be put on their inspection schedule. a quick survey of the other pumps (this is a big station!) shows that 7 pumps no longer have the inspection sticker ( a violation of the law) and others have inspection dates that range from May 1999 to April 2000) ironically, this station is located about 3 miles from the state weights and measures office. the station is off Lakewood Dr in Olympia WA. (its the Arco station that you would see just off Hwy 101 at the Thurston County Courthouse exit)
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    One more to add to the Washington list. 2 pumps at the quickie mart next to the "old burnt out Evergreen Ball Room" on state rout 510 one appears to give a 4 mpg over the computer the other 5 under. Both inspected 1 3/4 years ago, both repaired since the inspection. I am sure of the latter because the displays were displaying garbage for several weeks a couple of months ago. One more fill up and I know which pump I will use.
  7. jamarimutt
    jamarimutt New Member
    985
    The Prius has an accurate system for measuring miles per gallon. Why continue to calculate mpgs the old-fashioned way?
    I know, old habits are hard to break. :|
  8. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    if there were any repairs made on the pump, then the inspection sticker should have been updated.
    if they were inspected less than 2 years ago, then they most likely were inspected because someone complained about the accuracy.
    im still waiting on my inspection request. i am positive the pump is off though. i figured that using those pumps lowered my overall mpg .6 mpg
    BUMMER!!
  9. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    Dave,
    Here's my gas spreadsheet if you find any benefit to some additional data.
    http://www.w8kc.com/priusmileage.htm
    BTW, I've seen three other 2004 Prius here in the past week. One last Wednesday pulling into Oakland University, one drove past me (and waved!) as I waited to pull into traffic at the end of our street on Friday, and On Sunday I saw one way the hell up in Marlette, MI. No response wave.
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well actually, im comparing the accuracy of the computer and the what is figured mpg using the gas pump figures.
    i am beginning to think that the computer is the most accurate measure and that variances are not due as much to bladder volume differences than the differences in the gas pumps.
    the reason why i felt this way was because, i was religiously alternating between the computer being over and being under the pump mpg's. this is attributable to the variances in the volume of the individual fillup.
    but then, i changed stations that i normally used and experience two tanks in a row that were below the computer mileage by quite a bit. (3.2 mpg and 3.8 mpg. up until this time, i was less than a mile apart from lifetime computer verses pump mpg.)
    right away, i suspected something fishy. when i got a third tank that was under the computer mpg then i was convinced my theory was correct.
    i am now waiting for positive confirmation from the state on my findings.
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I know at least one of the pumps was updated since the sticker because for the last few months the display said one morment please. It is fixed in the last month! BTW that is the pump that is giving me a mpg that is much lower than the computer.
  12. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well good question, at least that is what i thought when i first got my Prius. and i did add the pump mpg's so my spreadsheet didnt look so anemic to be honest with ya.
    but serendipity has struck again. i have begun to realize that i can use the computer to gauge how accurate the pump is. i quickly noticed a pattern when using a certain pump that im positive is shorting me at the pump. the reason was 3 consecutative tanks when the pump was lower than the computer. something that has never happened before.
    previously, i alternated between being over and under the computer reading. remove the times i used the suspected short pump and the difference bet pump and computer is .8 mpg. now realize that i have had tanks that were as much at +3.4 to -2.8 mpg. but that is due to variances in tank fill levels.
    but getting short or over 3 times in a row means that a measurement is off. so the possible culprits are the computer being in error or the pump in error (assuming you dont spill any gas, etc) seeing as it has been shown in a study performed by KING % news this past spring that 11% of the pumps in the state are inaccurate, i have to blame the pump.
    to further test my theory, i went to where i was getting the best mpgs (yes i tracked location and pump # too...so more of that macho spreadsheet thing :roll: ) and i now im sure of my findings. i will have fairly definitive proof Fri Afternoon when i gas up. that will make 3 tanks at the suspected worst pump and 3 at the best pump.
