I tell you, check your tire pressure
Discussion in 'Gen 2 Prius Fuel Economy' started by siliconhybrid, Jun 21, 2007.
  1. siliconhybrid
    siliconhybrid Member
    121
    Bay Area California
    I bought another prius 2-3 weeks ago after mine was totalled from an accident.
    I was a little disappointed that I only got 44mpg for the first full tank. I got 48mpg from my 'old' 2007 Prius in winter, California winter that is. I checked the front tire pressure, it was 36-38psi so I increased the pressure to 42psi, to my huge surprise, I am getting 53mpg now.
    - My 'old' 2007 pkg#4 before accident / total loss with 42psi = 48mpg
    - My new 2007 Touring pkg #6 with 38psi = 44mpg
    - My new 2007 Touring pkg #6 with 42psi = 53mpg
    Sure it is a little bumpier with 42psi, but I take that for 9 mpg increase, that's 90 more miles per tank.
  2. Enoyls
    Enoyls New Member
    48
    <div class='quotetop'>QUOTE(siliconhybrid @ Jun 21 2007, 02:56 PM) [snapback]465910[/snapback]</div>
    That is an impressive increase. Time to check my tires B)
  3. tochatihu
    tochatihu Senior Member
    9,057
    3,529
    Kunming Yunnan China
    2001 Prius
    Tire rolling resistance is a particularly large slice of the 'energy pie' at low speeds. At higher speeds, suitable high inflation will help keep your tires cool and also help them to last longer. So, when going slow, it saves fuel money. Fast, it saves tire money. That's all I've got.
    All Prius drivers ought to have an accurate pressure gauge and use it. A 12 volt plug-in air pump would not be a bad idea either. Find the maximum cold psi of your tires (printed on the sidewall), and work down from there as ride comfort dictates. Keeping the fronts 2 psi higher than the rears is a common suggestion. If this is not enough to keep your edge treads from wearing out faster, check the suspension alignment.
  4. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Don't forget that the new Prius has new tires, and they have to break in a bit, too, for the best MPG.
  5. siliconhybrid
    121
    Bay Area California
    Well, my 'new' Touring Prius is actually a used one, bought it at 7000 miles.
    Nonetheless, point taken.
    <div class='quotetop'>QUOTE(Rae Vynn @ Jun 21 2007, 05:43 PM) [snapback]466060[/snapback]</div>
  6. wiiprii
    wiiprii New Member
    148
    Increased tire pressure to 44/40 on my 07 with 5200 miles on the clock, still getting 44mpg even after hitting reset on the MFD. Not trying hard to drive like an old man either, and use AC more often than not. 44mpg is still great, but I wonder if the people getting 53mpg know something I don't know...
  7. alexstarfire
    alexstarfire New Member
    220
    Yea, we don't use the AC. The AC literally kills the mileage man. I go from averaging 65 a tank without AC, to like 35 with AC.
  8. GeekEV
    GeekEV Member
    417
    NorCal, USA
    <div class='quotetop'>QUOTE(siliconhybrid @ Jun 21 2007, 11:56 AM) [snapback]465910[/snapback]</div>
    Having heard similar testimony from others in these forums, I bumped mine to 42 some time ago -- and haven't seen any significant increase... I guess it depends on your driving style, eh?
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(Mr. Zorg @ Jun 21 2007, 06:36 PM) [snapback]466085[/snapback]</div>
    Driving style and conditions are a big factor. With so many variables it is impossible to attribute the effects to the causes. Driving in the low 90F temps in the evening can knock 2mpg off my current tank. I can get 1mpg back driving in the high 60F temps in the morning. Harder tires and a partially blocked grill help. With an almost 20mpg difference between "identical" cars (all Prius were hatchbacks) on the same route I still believe the driver makes the most difference.
    Rank by mpg
    mpg
    M.M. Insight Hybrid 79.88
    W. Phila. Attack Biodiesel 66.52
    Hobbit Prius Hybrid 63.74
    R. G. Jetta Diesel 62.03
    W Phila. Jetta Biodiesel 59.30
    N.H. Prius Hybrid 58.65
    JimN Prius Hybrid 56.68
    M.S. Insight Hybrid 54.94
    E.K. Prius Hybrid 53.82
    St Mark's Jetta Biodiesel 44.47
    J.A. Prius Hybrid 44.23
    T.H. Camry Gasoline 33.53
    My interpretation of the results of
    The Tour to the Shore 2007
  10. Tideland Prius
    16,147
    Hmm.. I'm at 58.8mpg with 38/36 lol.
  11. darelldd
    6,057
    389
    Northern CA
    There's just no physics to back up such a huge MPG increase from such modest pressure increases. Tire rolling resistance simply can't add (or subtract) that much from the equation. Not within those boundries!. If you'd gone from square to round tires we might have something.
    But hey - If it is working for you, keep it up. Nothing to complain about if you can maintain that kind of mileage. Try going to 50PSI and see if you can get up into the 70's!
  12. siliconhybrid
    121
    Bay Area California
    Well perhaps it was around mid 30s rather 38, i dont know... it was dark at night, but I am sure I increased it to around 42. This afternoon I bumped my mpg to 54 with 100miles after reset.
    What I notice, the electric motor seems to be 'stronger'. When the pressure was at mid 30s, on flat road, going from 0 to 15mph, the ICE started kicking in. After increase to 42psi, going from 0mph, the ICE kicks in around 40mph at the same road.
    The gliding on freeway also feels longer now i.e. less tire resistance
    Oh well... I'm just passing the news, believe it or not, it doesn't matter to me.
    <div class='quotetop'>QUOTE(darelldd @ Jun 22 2007, 02:39 AM) [snapback]466243[/snapback]</div>
  13. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Using the Prius MPG simulator, increasing tire pressure in Goodyear Integritys from 38/36 to 44/42 raises MPG from 58.62 to 61.11 MPG at 55 MPH. At 35 MPH it goes from 82.12 to 86.76 MPG. This assumes the following:
    Steady speed on level terrain
    Smooth dry pavement
    E10 fuel
    80F ambient temp
    No winds
    300# load, occupants + cargo
    No AC use
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Indeed any short term improvement witnessed really can't be attributed to the tire pressure. Over the course of 10-20 tanks you should note a trend toward higher mpgs assuming that your commuted and driving conditions stay relatively stable.
  15. bwilson4web
    15,518
    If there is an alignment problem, lower tire pressures will put more tire edge material in contact with the road and lead to higher drag. I used an IR thermometer to measure the tire tread temperature as a function of different pressures last fall when I knew I had a rear wheel alignment problem:
    The right front tire had -0.86 degree camber versus the left front tire -0.53 degree. But I noticed that using max sidewall pressure changed the temperature profile and reduced the outer tread temperature. I used high tire pressure to mitigate an alignment problem until I could get the alignment fixed.
    On my first tire rotation, the front tires were even at .53 both inner and outer for both front tires. However, one rear tire measured .77 and .78 giving some evidence to asymmetrical wear. Since I had received a shim kit, I also bought the "life-time alignment" service. I used this service to get a measure of which size shim provides what amount of correction. Now my rear tires are at -.08 and -.07 toe and -1.1 and -1.1 camber.
    I still have an asymmetry on the front camber, -.50 and -1.0, and hopefully will get that corrected this weekend. Then I'll be ready to repeat the tire temperature profile test. BTW, I had some rolling resistance data pre-alignment but the results look "too good." I don't post data that I don't feel good about. Since I can install and take out the shims easily in the field, it is similar to changing a tire, I may do this just to find out.
  16. siliconhybrid
    121
    Bay Area California
    <div class='quotetop'>QUOTE(efusco @ Jun 22 2007, 06:38 AM) [snapback]466260[/snapback]</div>
    I'll certainly update my mpgs after another fillup. This morning, again I'm getting 54mpg (now 125miles after reset) same commute, same time of the day. I was thinking for a while about my sudden increase in mpg last night, I also doubt the tire pressure alone contributed to this big increase. My speculation: I mentioned earlier that my electric motor got 'stronger' after psi increase. I think with lower psi I was getting frustrated driving the car because hitting 15-20mph ingites the ICE, thus can't do much pulse/glide, while with higher psi I was able to go 40mph before the ICE started (due to less rubber ressistance) this leads to a lot more pulse/glide. I suspect I changed my way of driving from the psychological frustration at lower psi to better pulse/glide at higher psi.
  17. darelldd
    6,057
    389
    Northern CA
    Regardless of WHY you're getting the high numbers, the most important part here is that you ARE getting the high numbers. That's awesome. I run high pressure too (higher than you) but it is my technique that has the most impact on mileage. I can get 40 or I can get 55. I normally get 51-52 - you're doing better than I am, certainly. At least so far!
  18. h2photo
    h2photo Member
    432
    Chandler, AZ
    Checked my pressure today, all 4 are around 35PSI, but I just picked up the car on Wednesday, so they haven't broken in yet. Getting fairly decent mileage, its at 50MPG now (134miles on the car) But I also drive with AC CRANKED as its 108 today. I notices the worst mileage while going up the hills & accelerating. I still haven't managed the accelerating properly!
  19. siliconhybrid
    121
    Bay Area California
    <div class='quotetop'>QUOTE(h2photo @ Jun 22 2007, 04:43 PM) [snapback]466577[/snapback]</div>
    50mpg with AC on, that's pretty good. I'm lucky to live in CA Bay Area (despite the earthquakes and the home prices), I only turn my AC or +1 level up.
    I would be interesting to know the comparison, continue as is 35psi, note the mpg. On the next fillup, add the tire pressure to around 42-45 front and 40 rear, and see how much mpg you are getting.
  20. h2photo
    h2photo Member
    432
    Chandler, AZ
