I think I'm getting the hang of this Prius thing
Discussion in 'Gen 2 Prius Fuel Economy' started by jimmylozza, Feb 21, 2007.
  1. jimmylozza
    jimmylozza New Member
    140
    :D
    Not bad for just under 2,000 miles on the odometer. The warmer weather started here and at about the same time I found a station with what I believe is better gas (whether that be less Ethanol or a true 87 Octane, who knows).
  2. Dave
    Dave New Member
    340
    Santa Cruz, CA
    Yes, that's pretty good milage you're getting as a new Prius driver. With a name like yours, I'm not surprised.
  3. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    There are days when I wish I had a camera phone or a digital camera in the car. This afternoon the temp was around 45ºF and by the time I got home, there wasn't a single segment under 50. Days like today make me smile.
    And Les, so do displays like yours. Keep up the good work!
  4. Tideland Prius
    16,151
    very nice! Keep it up!
  5. TonyPSchaefer
    14,816
    2,498
    66
    By the way, I have to know where you were holding that camera to get that particular angle. Were you using some sort of "crotch-cam?" :lol:
  6. chuck kershner
    chuck kershner New Member
    25
    <div class='quotetop'>QUOTE(Les Gas @ Feb 21 2007, 08:04 PM) [snapback]394280[/snapback]</div>
    I definitely have one of the 40 and under vehicles. I've never seen a display like this after 4400 miles. Right now the display shows 25.3 mpg average in snow and 20 degree cold. But the car is still a lot of fun to drive and mileage per gallon, when it becomes an obsession, is a weakness that detracts from the overall value of the vehicle. It's much easier to drive with the Screen Off and look at the beautiful winter scenery - and watch the road and not the monitor.
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(chuck kershner @ Feb 22 2007, 01:28 PM) [snapback]394643[/snapback]</div>
    Chuck,
    You definitely need to block your grill. Might get you into the low 30's.
  8. Prius The First
    Prius The First New Member
    141
    Dig this.....[attachmentid=6672]
      File size:
      224.5 KB
      269
  9. jimmylozza
    140
    My Prius had been getting about 46-47 over the winter until this tank. Summer formula, maybe?
    I'm up to 51.7 today.
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Feb 22 2007, 08:07 AM) [snapback]394458[/snapback]</div>
    I had it braced against the steering wheel and used the camera's timer so it wouldn't shake during the 1/4 second or so exposure. The wide angle lens probably makes look like a shot from the crotch! :lol:
  10. hill
    8,172
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Feb 22 2007, 10:07 AM) [snapback]394458[/snapback]</div>
    I love my crotch ... cam :lol: Mine has the manual zipper model (better quit while I'm ahead) Today I'm on my blinking pip for 30 miles. MPG reads 60.1 !!! And the drives have been in 50 degree weather! Mileage on this tank is at 550 miles. That dang bladder shure gits shriveled up on cold day refills.
  11. MarkMN
    MarkMN New Member
    226
    Downtown Minneapolis
    My prius has about 400 miles on it and so I took it for a drive on the outer highway loop last Friday afternoon to break it in a little. The temp was 34 F and the length of the trip from my apartment to the loop, all the way around the loop, and back to my apartment was 134 miles. My mileage for the entire loop which had a range of driving conditions from stop/go to 75mph was 50.6 mpg. I was so happy. Most of my trips are between 1 and 4 miles and the car never gets a chance to warm up in this weather so I have been getting about 36-42 mpg. If I had a camera I would have snapped a picture to complement "Les Gas"'s picture!
  12. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    <div class='quotetop'>QUOTE(JimN @ Feb 22 2007, 09:32 PM) [snapback]394976[/snapback]</div>
    How do I block the grill? I actually don't even know what that means... Thanks.
  13. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(Michgal007 @ Feb 26 2007, 12:42 PM) [snapback]396759[/snapback]</div>
    Check Tony's post here: http://priuschat.com/index.php?s=&show...st&p=364407
    I found it adds about 10% to my mpg, cost about $2 (ask for copper/steel pipe insulation in a hardware store), took about ten minutes to install, your results may vary. efusco has an alternate method, but that's the expensive route requiring tie-wraps. :lol:
    I'm guessing Chuck Kershner also has a short commute, in which case the engine block heater might be the feature for him. Blocking the grill helps when driving, but I think he's seeing the initial startup mileage getting the engine warm before wind over the engine block even becomes an issue. And double-check the tire inflation, of course.
  14. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    On a bumper to bumper 10 hour trip from Las Vegas last President's Day, we were able to totally "yellow-out" our screen. I should have had the camera handy! :)
  15. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Prius The First @ Feb 23 2007, 09:22 AM) [snapback]395248[/snapback]</div>
    Looks great, and it can double for an ad for Cingular.
  16. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    By any chance, do you go down I635 in the morning?
    If so, maybe I've seen you.
    Yes, it looks like your run was above par!
  17. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(Michgal007 @ Feb 26 2007, 01:42 PM) [snapback]396759[/snapback]</div>
    A video might help you also. http://video.google.com/videoplay?docid=-4...51993&hl=en
  18. desynch
    desynch Die-Hard Conservative
    607
    Lakehouse
    Blocking the grille on your car has got to be the stupidest ting I've ever seen.. Sorry. I don't care if you think you get better MPG.. thats just stupid.
  19. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    HMMM! 16 miles in 25 minutes? 1.5 MPH must have been a long traffic jam.
  20. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(seasalsa @ Mar 2 2007, 06:51 PM) [snapback]399370[/snapback]</div>
    Huh? 16 miles in 25 minutes is more like 38 mph.
    Dave M.
