I think my brake regen failed...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DJ Q, Jan 20, 2025.
  1. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    So this happened a few hours ago.
    While driving, these lights came on on the dashboard
    Ignore the seatbelt light... I was stopped and parked at the time the pic was taken lol.
    When those lights came on, I noted that when I pressed on the brake pedal, there was ZERO response until I dipped lower here the friction brakes would kick in. The CHG bar was also not increasing when I touched the pedal.
    I have no check engine light on, so my head unit won't scan for anything...
    I can also hear the brake boost doing some very short pulses.
    I have a video with it doing that but I can't seem to upload it here.
    Any suggestions :-(
  2. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    Suggestion to count errors to determine the reasons for failure. Best with a scanner specifically designed for this purpose.
  3. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    I have an OBD-II wifi scanner at home.
    Was planning to check on it later to see if I get anything.
    Sigh
    Still love this car though
  4. Mendel Leisk
    40,472
    Anything constantly plugged into the OBD port?
  5. bisco
    51,030
    you need a prius aware scanner
  6. ChapmanF
    17,186
