I Think My Project Lithium Battery Failed After 3-days.
Discussion in 'Gen 2 Prius Main Forum' started by TheLastMojojomo, Sep 30, 2022.
  1. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    I think my Project Lithium Battery failed today at 3-days old. (Note: The video below is sped up to 1.5x)
    This is a message/video l've sent to Nexpower for what I believe is a failed 3-day old Project Lithium Battery pack. The screen recording above was made real time as I was trying to figure out what was happening to my new Project Lithium Hybrid Battery....
    I just installed a brand new Project Lithium Battery in my 2009 Gen 2 Prius with 204k miles.
    I believe the Battery has failed after 3-days. I am a mailman by trade. Meaning I'm constantly doing regenerative braking and harsh acceleration for 5 hours a day repeatedly. I'm constantly putting 100's of amps in to and out of the Hybrid Battery every time I pull up to or leave a mailbox.
    Initially I was super excited... I installed my Project Lithium Battery on Tuesday and did easy on the car highway commutes for the past 2-days. Everything was working great.
    This morning I brought my Prius onto the mail route for the first time since the install. At first everything was great. I was astounded by the difference the NexCell Battery was making in terms of Hybrid Battery Temperature, Internal Resistance, and had improved my mpg's by about 5. I was sitting between a 65-75% SOC the whole route due to the Hybrid Battery being able to take the repeated regenerative braking of 100 amps to each mailbox due to the low Internal Resistance allowing the Hybrid Battery to stay cool. Hybrid Battery Temps remained below 104°F (according to the temp sensors anyways) the whole day so max charge was always allowed.
    Then about 2/3rds of the way through the route... Cell # 14 appeared to fail as explained in the video.
    I'm wondering if the constant regenerative braking/discharging while accelerating on the mail route is the main cause and the Battery Modules just can't handle it. I'm skeptical of the actual quality/longevity of Project Lithium now. Maybe this was just a one-off event... and a replacement cell will fix it and I'll be good for years.
    I just emailed NEXpowerenergy/Jack and will be waiting for a reply. I would be willing to replace the damaged cell if Jack thinks this was just a fluke. But I would be putting the Hybrid Battery through the absolute torture test everyday. Repeated non-stop regenerative braking and discharging at 100 amps 200+ times a day. I'm not convinced at this point Project Lithium can handle that if a cell has already failed in 3-days.
    Luckily I still have my 13 year old OEM Battery Modules to fall back on if I need to... But as of now I'm very disappointed in Project Lithium... $2,400 spent and failed in 3-days.
    However, it is possible I may have screwed something up upon installation... But I made sure to Torque everything correctly... Busbars were torqued to 48-in.lbs. I will be taking the Hybrid Battery apart again tomorrow to double check my work.
    #1 TheLastMojojomo, Sep 30, 2022
    Hotrod325, TGrracie and douglasjre like this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,411
    2,415
    Durham NC
    Well like anything else that gets manufactured I guess there can be a bad such and such and so and so under the hood or under the cover as the case may be. So there's that others seem to be having very good luck with the battery so I would hope it's a fluke and you'll get it worked out and that'll be that. So then with regular battery tech from the Prius to nickel metal hydride everything was good with your Prius on the route and everything else or maybe that battery was old and tired got it I have an '09 with the brand new Toyota battery everything seems to drive great 47.1 etc. I run it as a service vehicle I don't think I try to break next when I pull away from what would be a whipping post or a mailbox or someones shed etc . But we drive the heck out of the car.my battery's never been over you h bottom of case hot maybe 110 or. So. Is that too hot when it's 100° out?
  3. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    The hybrid mechanic guy from Miami who posts YouTube videos on the PL battery and it’s components mentioned, in his detailed disassembly video, that the reason he did the disassembly was because he had to replace one or more cells anyway that failed early on. So it does happen it seems.
    TheLastMojojomo and douglasjre like this.
  4. Another
    1,819
    517
    Naples, Florida
    Harbor Freight has 1/4” torque wrench on sale this weekend.
    20 to 200 inch pounds.
    $12 with coupon code 31458366 online or in store
  5. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    any chance you can send a listing link? i will go buy one today
    PriusCamper and ColoradoCrow like this.
  6. nancytheprius
    365
    156
    iowa
    jzchen and ColoradoCrow like this.
  7. PriusCamper
    PriusCamper Senior Member
    13,055
    5,305
    Pacific Northwest, USA
    Yes, a P3000 error code... Would love to know which subcode if you access to Toyota Techstream?
    But there's no issue with the pack... I've been testing a prototype version of exact design in a Gen2 and Gen3 Prius for 2 years now. The problem you have is most likely corrosion inside the hybrid battery ecu that's causing bad readings/microshorts in block 14:
    Taking apart and cleaning or replacing the ECU will fix this. Also replacing the voltage sensor harness (Wire Frame No.2) with a new one helps because that's how the corrosion gets into the ECU via seepage at old NiMH pack's negative terminals. This is a known problem with older Prius in humid areas and nexcell has only had 3 packs out of 200+ sold with this problem. So now you're number 4. But with just a couple hours work you'll have this problem fixed.
    To address this problem in the long run the voltage balancing electronics in the Nexcell module(s) are being updated in version 2.0 to prevent these bad readings even when corrosion is present.
    #7 PriusCamper, Oct 1, 2022
    veggiecar likes this.
  8. pasadena_commut
    pasadena_commut Senior Member
    2,844
    849
    Southern California
    The picture shows surface corrosion. Unclear to me how cleaning that off is going to make a bit of difference in the electrical properties of that part of the conductor. If you mean that the corrosion goes right through the plastic and the conductor on the other side is also corroded, so that the connection to the pin (or whatever) on the other side is compromised, then yes, cleaning it will reduce the resistance through that connection. Unfortunately, perhaps only temporarily. If the outer plating metal (gold in the best case) has been displaced by the corrosion then the underlying base metal (nickel, copper, some alloy?) is not protected and may corrode again pretty quickly. I once had to repair an instrument at work because of this issue. Cleaning the contacts didn't stay fixed, it eventually required removing the entire socket on the circuit board and replacing it, even though only a couple of pins were affected.
  9. jacktheripper
    jacktheripper Senior Member
    276
    550
    Hi @TheLastMojojomo ,
    Thanks for sharing the info, as we discussed in the email, we will help you find the root cause as well as provide warranty if battery is indeed the source of the issue.
    Best,
    Jack
    TheLastMojojomo likes this.
  10. jacktheripper
    276
    550
    yes, I always advised to replace the battery ECU if corrosion were found, problem with corrosion is that it short the battery blades and slowly drain them, a new ECU is about $220 new from dealership and $100 used from eBay.
    @PriusCamper is the first person that I know of ever attempted of the repair/clean up, seems to be holding up so far.
  11. jacktheripper
    276
    550
    That's my buddy Jose from Trinidad and Tobago, he got my consent to post the video on YouTube since the Ver. 2 will be out shortly :)
    and yes, battery issue is inevitable, playing with chemistry is hard but a more robust QA process can definitely help.
  12. PriusCamper
    13,055
    5,305
    At first it just creates noise/bad sensor readings from micro shorts but as it grows it will eventually short out the plug on the other side. It's very common type of hybrid battery failure in areas with high humidity like Florida and Pacific Northwest... I've got a whole box of hybrid battery ECUs that were all fried in the exact same way and we're hoping to one day track down a supply of female plugs so we can repair the circuit board because the only damage is the plug.
  13. ForAMorePerfectCommute
    ForAMorePerfectCommute Junior Member
    31
    Central Florida
    Just be wary of those cheap torque wrenches, I had one that failed to click and ended up with a broken valve cover gasket bolt...
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Can you provide a link for this? I'd buy 10 right now.
    maybe you meant to say "a new ECU is about $720 new from dealership"?
    #14 TMR-JWAP, Oct 2, 2022
    PriusCamper likes this.
  15. pasadena_commut
    2,844
    849
    Southern California
    Often the manufacturer's name is stamped somewhere in the plastic, but a big magnifying glass may be needed to read it. It might be on the bottom part, blocked by the circuit board. If so, unsolder the connector and have a look. It might also be in the narrow area above the pins in the contact region.
    The other approach is to measure the pin number, spacing, and geometry, then start on a site like Digikey or Newark and use the filters to narrow the field until you find either the original connector or something compatible with it.
    Worst case scenario - it is a custom part made by Denso (or whoever) only for Toyota. All hope may not be lost though. With a lot more work, one could probably still find a plug/socket pair which has the appropriate geometry to mount on the board, but one would have to rewire both sides of the circuit. The socket's are usually pretty easy, but redoing 20 (?) pins on a plug can be a PITA.
  16. PriusCamper
    13,055
    5,305
    Yeah, I've been quoted $800 from the stealerships more than once... Bunch a criminals! Used to be a used battery ECU sold on Ebay for $50 but supply for Gen2 is dwindling and price is soaring. Wish I hadn't thrown away those first couple fried ECUs.
    As for cleaning and reusing an old ECU a friend told me Aqua Net hairspray from the dollar store is a cheap lacquer that would prevent the corrosion from coming back? What do you think?
  17. TheLastMojojomo
    232
    181
    US
    Just an update to this thread.
    @jacktheripper has been extremely helpful to work with. He is already sending me a new Project Lithium Battery for free and I'm hoping this one lasts.
    Last night I made this Video:
    I compared the Dr. Prius Voltage readings that are being transmitted by the Battery ECU to actual voltage readings with a volt meter hooked up to Battery Modules #13 and #14 while under charge. They match, indicating that the HV Battery ECU is not the problem... Also just from my observations... The Battery ECU does not appear to be acting wonky in anyway... The problem appears to lie within the modules.
    I will be taking the Battery ECU apart (or at least check the pins for corrosion) before my install of the new NEXcell Lithium Pack being sent to me. I am also going to document everything I do with video in excruciating detail from here on out. I'm even going to do screen recordings/video of how the new Project Lithium Hybrid behaves when under constant 100 amp regenerative braking and discharging every-time I pull up to and leave a mailbox from 60-0mph/0-60mph 100's of time a day. I believe that is what caused the 1st one to fail on day 3. I am hoping the 2nd one will be able to handle the stress. If the 2nd one fails in a similar manner... it will prove that the Project Lithium Battery can not handle the stress of a mail route due to all the constant non-stop charge and discharge stress.
    I do actually have Techstream. I just checked the codes. Here is a screenshot:
    No P3000 anymore.
    P0A0D is because I have the orange interlock switch removed. Otherwise P0A80 is the only other relevant code... which indicates Hybrid Battery Failure. The other codes are just a consequence of the recent 12v disconnect or P0A80 I think... and B1421 is because no sun is hitting the solar sensor. Nothing indicating Battery ECU Problems.
    Would the 2nd video I made above indicate it is not the Battery ECU and that instead it is in fact the Modules?
    #17 TheLastMojojomo, Oct 2, 2022
    Fred_H likes this.
  18. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    2 years of use with my nickel metal hydride battery pack and all the cells have almost exactly the same voltage. Never seen anything better balanced in my life
  19. pasadena_commut
    2,844
    849
    Southern California
    Well, one could certainly coat the metal with an insulating water tight coat. However, after that one couldn't see if the metal was corroding underneath unless it was enough to displace or discolor the coating. (More or less like rust on a car under the paint.) If the coat was transparent that would help, not sure if any are though. Maybe this one, which is "clear":
    EL600 Clear Insulating Varnish | Sprayon
    If you do want to try protecting the metal use a product actually designed for the task. 3M makes two types of spray on insulating coating.
    https://www.3m.com/3M/en_US/p/d/b00040353/
    Google for "paint on electrical insulator" and many products appear. The paint on stuff should be less expensive than the sprays, and probably safer to use, since breathing small droplets of this stuff cannot be a good thing.
  20. PriusCamper
    13,055
    5,305
    Thanks for this info... Many of the larger hybrid battery rebuilders claim they offer an "upgraded battery ECU" and have always wondered what that means. Because no one has every announced success reprogramming a Prius battery ECU my hunch is spraying on this stuff after they clean any signs of corrosion is what they mean by upgraded.
