I tried to jump start another car with my Gen3... Am I in trouble?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by novagui, Jun 10, 2019.
  1. novagui
    novagui New Member
    Hi there,
    My wife's car (2010 Elantra) was dead this morning so I tried to jump start it with my Gen3. Didn't know it was a bad idea until a Googled it to figure out why it wasn't working.
    The jump starting process didn't work (her car couldn't start). I tried once with the Prius engine turned off completely (didn't start the Prius at all) and once with the gas engine running. In both cases, her car couldn't start.
    I used my car afterward and didn't notice anything unusual. I also plugged a 12v battery charger to it, in case I drained my own battery during the process (the cars were connected for less than 5 minutes).
    Do you think I may have broken something? What are the odds? Getting a little paranoid here. Will never do it again for sure...(bought a portable jump starting kit).
    Thanks!
  2. Mendel Leisk
    38,726
    You should be good.
    I jumpstarted a Nissan Maxima maybe a dozen times, with an 06 Civic Hybrid, before I read up, decided to get a jump pack, a JNC660. No harm came of it, but yeah best to play it safe, use a jump pack.
    What kind of charger are using? A "smart" charger, 3~4 amp range, is good. In the Owner's Manual Toyota recommends 4.2 amp max.
    I think somewhere they also mention to take the battery out before charging. I'll call BS on that: I have a quick-connect installed in the engine bay fuse box, and ours is on a charger more than off, a CTEK 4.3 that can be left on indefinitely. The car often sits idle for multiple days, so I've adopted that strategy, so I don't have to worry about it.
    If you want to see where you're battery's at, look into something like Solar BA5.
  3. novagui
    novagui New Member
    Thanks, you're making me day a little better :)
    I'm using a 800mA charger... so I guess I should be good.
    49,488
    jump starting is fine. jump starting improperly may not be
    Raytheeagle and Mendel Leisk like this.
  5. novagui
    novagui New Member
    No trouble code so far (I have an UltraGauge scanner plugged in).
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Your post is confusing.
    Does your Prius start and run OK now or not ??
    There is nothing wrong with a jump done PROPERLY.
    There are just too many things that can go wrong.
    You greatly minimize the odds of a bad outcome if you never start the Prius.
    If there WAS a problem caused by improper procedures ........or a shorted battery at the other end.......you would know it immediately.
  7. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    o_O
  8. novagui
    novagui New Member
    My car seems to work properly, yes. I guess the part where you say "If there WAS a problem caused by improper procedures ........or a shorted battery at the other end.......you would know it immediately." is the most reassuring, then.
    Thanks.
  9. Mendel Leisk
    38,726
    Oh geez, another quote for @Grit ...
    Raytheeagle, RMB and Grit like this.
  10. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    I’ve got a whole set of new quotes, just need time set aside to do it.
    Raytheeagle, RMB and Mendel Leisk like this.
  11. novagui
    novagui New Member
    Well, in my defence the fact that I didn't notice anything strange while driving it right after the jump start process doesn't mean I haven't broken anything... some people have reported issues happenning shortly after they tried to jump start another car (in the following couple days).
    #11 novagui, Jun 10, 2019
  12. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Google? Call me old fashion (owner's manual)
    Raytheeagle likes this.
