I unplugged the battery fan and got a C1259 & POAOD Code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by latitude500, Mar 21, 2019.
  1. latitude500
    latitude500 Junior Member
    austin, tx
    I was putting in some sound deadening material in the back of the car. I removed all the trim and removed the battery fan for a fast cleaning. But when I plugged the fan back into the car, I got two codes C1259 and POAOD. I must have not plugged everything in right, or moved something around. Man I feel dump.
    What do I need to do to fix this issue. I powered the car on and the fan did come on so I know it's working at least.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    You could unplug the 12 volt battery and see if the codes return.
    FuelMiser likes this.
  3. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Delete the codes
  4. ASRDogman
    ASRDogman Senior Member
    6,092
    3,273
    After deleting the codes, or disconnecting the battery for a while to delete the codes,
    slowly go over everything and make sure you connected everything correctly.
    Look at anything close by you may have disconnected or damaged.
  5. latitude500
    austin, tx
    That did it. I cleared out the codes and unplugged the battery for the night. Put everything back together and she is good to go. Thank you for your help everyone.
    Raytheeagle likes this.
