I want to change from a Fit GE6 - Prius 30
Discussion in 'Newbie Forum' started by Curious-Octopus, Jul 11, 2022.
  1. Curious-Octopus
    Curious-Octopus Junior Member
    Japan
    Good day friends. Currently I'm driving a GE6 Honda Fit. The road noise is unbearable(I have hyperacusis) on some rough streets here. I tried changing the tires and it got worse so I had them swapped back to the old ones. The suspension is also pretty hard. I test rode(can't drive here) a Prius touring model. While the suspension was hard, I realized it was softer then my 2nd Gen Honda Fit. Road noise was also quieter despite not being a really quiet car.
    However it's an 09 Gen 3. It been ran 45,981 miles, which isn't bad, but I'm worried about the fact that it's the first year of gen 3. Also it's 2 years older then my Fit. I also read that the 2011 facelift improved quietness.
    I'm thinking it's better to see if the dealer can find me a later year of the same car. Any thoughts?
    Another question I have is how thin are the driver side windows? The windows on my Fit are thin enough that passing trucks and motorcycles hurt my ear. I feel like other cars I have driven were not as bad.
    I thought about saving money for a 2016 Gen 4. The issue I have is that it's more expensive and bigger(can be an issue here).
    Any advice would be appreciated
    Thanks!
  2. Mendel Leisk
    38,728
    Test drive seems like the best approach. I suspect you're not going to see a big difference in noise levels, in any of those. And yeah, tires are a factor.
  3. Curious-Octopus
    Japan
    I unfortunately can't test drive here unless I find a rental car. What I will say is the Prius didn't get obnoxiously loud on the highway at 100km and seemed more stable then the 2nd gen Fit. The Chassis noise from road imperfections was not much different, but it was at a tolerable level. Much more then the Fit. However this Prius had 17 inch wheels while my Fit has 14 and thicker walls. I imagine switching the Priuses wheels to 15 or 16 will help even more.
    Unfortunately as I wasn't allowed to drive I couldn't get a proper feel for the window noise.
    I'm at a loss because I already dropped what was equivalent to 500$ to swap tires on the Fit and I had to pay them to swap them back to the old ones because the noise was so bad I wanted to cry...
    49,500
    welcome!
    i had 2008, then 2012, did not notice improvement in road noise. i would either consider sound deadening the car (fairly big job) and quieter tires, or moving to a non hybrid like corolla or whatever is available there.
    tough to find quiet econoboxes though, so the sound deadening might be your best bet. lots of threads here on how to.
    if you are going to buy a gen 3, beware the egr circuit headhasket brake actuator problems.
  5. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    The Gen 4’s are improved on nearly all levels so maybe check one out?
