I was quoted 1250 for a repair for a timing cover reseal. Is this a defect on the Gen 3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by heyphillip, Dec 19, 2018.
  1. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    The job is about 13 hours anyone else run into this issue 20181219_155521.jpg
    49,500
    that's about right, but you can usually ignore it
    are you getting any oil under the car?
  3. working1
    working1 Active Member
    121
    111
    A common nuisance defect, but, likely not a recall worthy defect. The leak is small enough most ignore it, especially if outside the warranty coverage period. I'm approaching 213K miles and have no plans to fix it.
    tankyuong likes this.
  4. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
  5. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    So you have the issue also? I wonder if this has to due to the light weight of the recommended oil used that it's so light it seeps through the gasket
  6. bisco
    49,500
    there are lots of people here with the issue, and many thread. most ignore, unless it happens under warranty
    i think it's just a defective gasket, but the engine has to come out to get to it, iirc.
  7. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    That's to much money it won't get done unless the oil pores out like water
    bisco and Raytheeagle like this.
  8. Mendel Leisk
    38,730
    @heyphillip believe it or not, that's about the best price I've seen mentioned here. More typical is $1700~2200
    If you want to get an idea how bad it is, take off the front/right wheel, and a few of the fasteners holding the plastic panel at the back of the wheel well. Then you can see the driveshaft pulley (with no attachments, the engine oil filter housing and bottom of the timing chain cover.
    #8 Mendel Leisk, Dec 19, 2018
    SFO and bisco like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I was quoted $1700 for the job over 4 years ago at ~95 k miles. I had the extended warranty so it was covered, but if it wasn’t, I would have just left it be and monitored it;).
    Seepage isn’t worth the price(y).
  10. Mendel Leisk
    38,730
    There's absurdly detailed diagrams in the Repair Manial, on how to place the form-in-place gasket. The instructions say to apply it to the engine face, and that's not happening.
    The instructions say to apply the bead typically around ~3mm diameter, and to increase to around ~5 mm diameter at the 3 split-line zones. Very specific. And also to put localized lateral beads at the split lines.
    Then reinstall the cover, within 3 minutes of commencing with the FIP gasket application.
    Then install all the bolts, twenty five of them, and torque them all (there are differing torque values), within a further 7 minutes. So 10 minutes in total, from the time you start applying the gasket, to everything back in place and all bolts correctly torqued.
    Or start all over...
    SFO likes this.
  11. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    That price was quoted at Team Toyota out of Princeton NJ they also said the front struts were rotted new ones 689.00 dollars not surprised considering the car's original owner purchased and drove since owning the Prius new in Syracuse NY where winters are brutal
  12. bisco
    49,500
    any noticeable problem with the struts when driving?
    how many miles on her?
  13. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    No they just have surface rust on them other than that no noise coming from them going over bumps or nothing. Plus I think I can probably beat that price if I had to change them. I have 105,621 miles right now. I just got back home making a 83 mile one way trip averaging 62 miles per gallon I use the scan gauge to monitor my gas milage not the numbers on the dash after the round trip driving 166 miles total I only used half a tank of gas 20181102_160316.jpeg 20181102_155749.jpeg 20181102_160246.jpeg
  14. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    To do that timing cover it is almost required to pull the ICE. The job of pulling the ICE sounds intimidating, but it’s not. The water pump is 5 bolts, The exhaust manifold is 13. The motor mount is 6. The bellhousing is 8. This is going by memory, so I may not be exact.
    After you pull it once or four times (like I have), it can be done in a couple of hours. When I first started pulling mine for the first time, I thought “It will be a miracle if this thing ever runs again”. Just take your time and watch everything.
    m.wynn, SFO and Raytheeagle like this.
  15. Mendel Leisk
    38,730
    Do you leave the intake manifold on? Or could you?
  16. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    You can leave the intake on. Or off.
