I wish the Prius had....................
Discussion in 'Gen 3 Prius Main Forum' started by Gasitman, Nov 6, 2009.
  1. Gasitman
    Gasitman New Member
    118
    Washington
    what? What ever you think realistically, no it cannot come with Cindy Crawford as a passenger. :D
    I wish it had one of those LED lights in for the under shifter area storage. I can't see crap at night, they should put a light there for future models.
  2. brick
    brick Active Member
    1,083
    78
    Upstate NY
    The option for the user to program user-programmable options. If the sentence doesn't make sense, we shouldn't have to ask! That's just about reason enough not to upgrade IMO.
  3. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    another 100hp
  4. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Power seats with memory.
    2 people like this.
  5. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    Who wants Cindy Crawford as a passenger? Too much competition man.
    Actually, I wish it had more zip.
  6. pekinkaid
    pekinkaid Member
    Houston, TX
    a plug
  7. Tideland Prius
    16,123
    • All LED lights (interior/exterior like Lexus) as standard equipment
    • User-customisable screen (The HS has a vehicle settings menu and it lists ALL the customisable features that us Prius owners need to go to the dealer to get changed [door locks, lights etc])
    • Driver's side drop-down box. It'll be nice to be able to put change somewhere
    • Additional ambient lighting (I love the fact that they've thought of it for the Gen 3 but modern lighting has soo many possibilities for soft ambient lighting)
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Presets on the climate control, so I can set it how I want it and it stays that way. I don't want it to recirculate unless I press the button.
    A slightly wider, longer and more supportive seat. I don't know why the seat has a hump in the middle.
    A mute button on the stereo.
    Not much really.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    E85 capability, inside hatch release, and many more gauges. (Ideally, all OBD-II reports)
    I would like to able to program it to glide with no throttle, rather than give engine braking on no throttle. (This could not be the default, as it would not be what 'normal' drivers expect)
  10. SlowTurd
    1,156
    333
    nj
    all wheel drive with 55mpg
  11. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    Agree 100% about LED's.
    I would like to see 100% LED lighting.
  12. Gasitman
    Gasitman New Member
    118
    Washington
    Mine does. :confused:
  13. fuzzy1
    10,140
    On the climate control, separate the heat and AC setpoints such that when I turn off AC, the ventilation can go to LO (actually NO heat) rather than heating to the AC setpoint temperature.
    A button to bias the battery to a lower charge level, so that I can reach the top of the mountain with only 3-4 bars instead of 6. This is both to save fuel on the way up, and to have more room for regeneration on the way down, to delay that screaming engine braking when the battery gets filled. It is perfectly fine for this setting to require driver action for every use, and to cancel within 5 minutes.
  14. fuzzy1
    10,140
    In the US, those of us with Type B audio have it, those with Type A do not. See the manual, pages 291 and following.
    Pat is one of them furriners, who likely have different equipment.
  15. patsparks
    10,664
    567
    Actually Pat stuffed up. This is a Gen III forum, I have a Gen II.
    Sorry about the intrusion, carry on.
  16. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Locks on the glove boxes and the under floor storage cover. Window shades, heated mirrors and hatch release on key fob. I have to agree on a LED light for the area under the shifter. That one should be an easy mod since there is a blank switch near by.
  17. dogfriend
    7,512
    1,185
    Carmichael, CA
    Factory direct sales (no slimy, lying dealers)
    Included Scan tool software and any special tools needed for DIY maintenance included for a nominal (not ripoff) price for those who want to maintain their own car.
    A LED display in the corner of the rear hatch window that displays the iMPG and current tank MPG for all of those tailgaters to see. :madgrin:
  18. patsparks
    10,664
    567
    I like it! Most wouldn't get the instant MPG so I would just like the tank average displayed. Additional incentive to drive well for me too.
  19. Gasitman
    Gasitman New Member
    118
    Washington
    again, I have those, and I only have a package II:confused:
  20. Tideland Prius
    16,123
    umm you have heated mirrors. It's activated by the rear defroster button.
    Also a hatch release on a keyfob is kinda mute isn't it cause you'd have an SKS release button anyway...
    The Recirc thing is programmable (for the Gen II), isn't it?
