I would like to remove the backseat headrests....
Discussion in 'Gen 3 Prius Main Forum' started by JoanneR, Dec 19, 2012.
  1. JoanneR
    JoanneR Member
    97
    36
    Something is different with the backseats in my new Prius, perhaps the seats are bigger? When I travel, I use the footspaces behind the front seats for items, but I am not going to be able to do that with this new car. The backseat headrests are going to be in the way and not allow the back seats to be flat.
    Is there an easy way to remove those backseat headrests? I never have people sitting back there.
    P.S. Hope my description of the problem wasn't too muddy to understand.
    Thanks!
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Yes, I believe the instructions are in the owners manual and more useful than my description.
    Going from memory....Look at the plastic ring where the headrest posts go into the seat back. IIRC there is a piece you push in to unlatch the headrest so you can remove it.
  3. Much More Better
    Much More Better Active Member
    655
    163
    I removed the centre one. I don't know if you can remove the other 2. When fully extended, it folds 90deg. Maybe that helps?
  4. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    I've got my 3 back seat headrests resting under the panel in the back, they fit really well back there.
  5. NinnJinn
    NinnJinn Member
    276
    Indiana
    To sum up what xs650 said, the tab you push in to push the head rests down, push the tab and pull the head rest up, they will come out...
  6. jrb451
    jrb451 Junior Member
    59
    Conway, AR
    FWIW - I removed all of my back seat head rests to improve visability out the back.
  7. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    2012 headrests will flop forward, which lets the seatbacks drop down flat!
