ICE always running even under 42mph
Discussion in 'Gen 2 Prius Technical Discussion' started by ih8spm, Sep 15, 2017.
  1. ih8spm
    ih8spm Junior Member
    73
    29
    New York
    05 Prius, 225k miles with check engine light on for P0420. Brake light on also due to a leaking rear brake cylinder.
    I'm new to this prius world but from reading it appears my Prius never runs solely on battery even under 42mph. It will run in ICE immediately after 2-4 mpg unless I'm in a parking lot scenario. My trip data says I'm averaging 37mpg but from my fuel fill test I'm getting 41mpg. Was wondering if this is all normal? Thanks
    SM-G935P ?
    49,463
    probably normal for a car with 225,000 miles. your battery is likely weak, and the computers are protecting it from going south altogether. might be a good time to start using a prolong charger.
    SFO likes this.
  3. ih8spm
    73
    29
    New York
    That may be the case but I just bought this one and some of the cells were replaced previously. I did forget to mention I can never get to the green battery status so your probably still correct.
    SM-G935P ?
    49,463
    yes, a rebuilt battery, while 'new to you', is still full of old cells. i might be wrong, it's just a thought based on common sense, not a proven fact.
    have you cleaned the battery cooling fan and intake grille?
  5. ih8spm
    73
    29
    New York
    Yes the fan and intake were cleaned to a shine and sparkle. Going to get the torque pro app to check the cells.
    SM-G935P ?
  6. ih8spm
    73
    29
    New York
    Anything else I should check or is this just it for me?
    SM-G935P ?
  7. bisco
    49,463
    you didn't get the triangle of death, so it might not be the battery. what are you reading codes with?
  8. ih8spm
    73
    29
    New York
    Elm327 with torque app
    SM-G935P ?
  9. ih8spm
    73
    29
    New York
    Update! I took the Prius for an 8 mile local ride down some pretty flat and downward sloping roads and I was able to achieve all electric mode under 42mph. I even saw my first green bar in the information center.
    SM-G935P ?
