ICE comes on anyway
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Feb 26, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    It doesn't matter what I do, climate prep, traction battery warmer, ICE always kicks in if speed exceeds 25 mph and outside temperature is 40 or below
    Arctic_White likes this.
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    If you wanted all season electric propulsion, you should have bought a BEV. You made the right choice with a PHEV though. Learn to live with its "limitations".
  3. mr88cet
    mr88cet Senior Member
    2,311
    1,334
    Austin, TX
    Maybe if you don't turn on the heater or front defroster, the ICE won't turn on. At that low a temperature, I'm not all that surprised it would turn on.
    iPhone ? Pro
    49,693
    the engine should not come on if you are doing it right, as reported by many others here.
    1) are you in ev mode?
    2) is the front defroster off? (not sure if this applies to prime)
    3) any downhills on the way that would use ice to burn off regen?
    i couldn't keep the engine off on my test drive, but i have been told i didn't have enough ev miles.:rolleyes:
    my pip engine rarely comes on all winter, if i operate it correctly, prime has to be better, i'm sure.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    On one of my test drives the temp was 34F and I had to use CHG mode to get some Ev range as the battery started out depleted. Even with only 2 miles or so of EV range it still went into Ev at 65mph, and stayed there.
  6. priuscatprimeguy
    2,730
    2,640
    Heater's off ICE still comes on:mad: Never turned on front defroster
    #6 priuscatprimeguy, Feb 26, 2017
  7. priuscatprimeguy
    2,730
    2,640
    1) are you in EV mode (check)
    2) front defroster off (check)
    3) Clawson is extremely flat (check)
    4) (Check)
    Ice still kicks in when temperature is 31 degrees F and I'm going faster than 25 MPH:mad:
    Adequate EV miles? (check) 28.7 miles EV
  8. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Sorry you have this problem. My Prime is acting as an EV, confirmed at 16F, never got colder to test below that.
    Right questions above.
    Have you tried not having a full charge?
    Or tried driving under 25 mph for a couple miles to get battery warmed from driving before proceeding to driving faster?
    Do you park it outside overnight?
    Only other thing I can think of is to see a dealer with experienced technician.
  9. bisco
    49,693
    has this been happening all along?
  10. priuscatprimeguy
    2,730
    2,640
    I have been driving at or about 25 MPH for a long time now. I decided today to try out going faster since I scheduled the charge for 9:00 am this morning with climate prep enabled. At 9:00 am I disconnected the EVSE, got in my car, proceeded to 14 mile road (35 MPH speed limit) after two blocks ICE kicked in. The Prime is acting the same as my 2012 and 2015 PIP which means I can't go faster than 25 MPH for at least a mile or else ICE will kick in. Yes, I park outside overnight. ( so much for Traction Battery warmer)
  11. priuscatprimeguy
    2,730
    2,640
    yes
  12. Lee Jay
    5,850
    4,024
    My guess is that you've got a bad temperature sensor in the battery somewhere. I'd take it to the dealer.
  13. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    I agree; Time to get it onto the shop. I'm located in Upstate NY, and since I've had my Prime, we've had many days under 20F, and I park and charge outside. I can make the work roundtrip (24.2 miles) all in EV, with a few miles to spare. We use the Seat Heaters, and only turn on the "ECO Heat/Cool" sporadically (to defog windshield). The ICE will kick on should I select the "Front" defogger, or I use the "B" mode before a few miles of EV are burned off. Are you in "ECO Mode" (I don't use the "Normal" or PWR" modes)? Are you in "EV Mode" or "EV Auto" (I think "EV Auto" s/w may cause ICE to fire in cold weather)? Good luck at the dealer.
    dalcon95 and giora like this.
  14. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Yeah, something ain't right, the only time I've had my ice turn on is when using defrost. Even up to 80mph. With temps in the 20's. I'd take it in and have it checked out, hopefully nothing big and get it back soon.
    Also, when ya do get it fixed, I found a trick to defrost the windows without having ice turn on. I click auto the direct vent to windshield. It works good enough most of the time. ;)
    priuscatprimeguy and bwilson4web like this.
  15. priuscatprimeguy
    2,730
    2,640
    I'm in the default EV mode. Climate is off. Went to dealer he showed me the parameters of when ICE kicks in during EV auto mode. I told him I'm in EV mode not EV auto. He couldn't find any issues with the battery warmer. Of course he had the car in a warm service bay so I really don't know how they were able to determine that the battery warmer was working. or not.
  16. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    That is going to be the problem with this new very technical model. Service dealerships are going to have to catch up on the mechanics of this car to be truly able to address the problems coming up with it. I wonder how many mechanics have been sent to classes to understand the car?
    #16 huskers, Feb 27, 2017
  17. bisco
    49,693
    call toyota and log a complaint. this could be a long and messy issue, unfortunately.
    ask the service manager to go for a drive with you.
    thatoneraccoon likes this.
  18. priuscatprimeguy
    2,730
    2,640
    I would ask the service manager to drive with me, but the logistics work against me. You see I have to drive to the dealership which means the battery gets warmed up during the drive there.
  19. thatoneraccoon
    201
    146
    Ohio
    Good idea Bisco has there, it was suggested to me when I was having problems and I can say it seemed like Toyota corp really cared about everything and they seemed to help. And because of them I found out there is a special Toyota engineer that goes around to all the dealer's for special cases, I'd even request the engineer and leave your car overnight with them.
    priuscatprimeguy likes this.
  20. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    Definitely been colder than 31F here several times (although given last week you wouldn't know it), and other than odd hill issues I have had no problems staying in EV mode well above 25MPH. I drive on the highway at 65 to 70 MPH staying in EV the entire time, and even have the climate system turned on.
    Defoggers will definitely turn on the ICE, you can not get the defoggers on during normal car run without the ICE turning on from my experience. You can turn on the defogger before going out to the car if you have an Advanced and setup your smartphone. Remote climate is one of my favorite things, defog the windows and de-ice the back window means I can drive without having these on and sucking on my gas.
    If your vehicle is turning on and you are positive it is in EV mode, then there has to be something up that requires a look. Perhaps arrange a loaner with the dealership and leave your car overnight, instructing them to leave it outside. Arrive when they open to take a scheduled drive with someone from service and show them the problem.
