ICE engine at start-up
Discussion in 'Gen 3 Prius Main Forum' started by rekniht01, Sep 10, 2012.
  1. rekniht01
    rekniht01 Junior Member
    Knoxville, Tennessee
    I'm a n00b, so bear with me.
    We are about 2 months and 3000 miles into our 2012 Prius II. It's great to be able to double our milage, and half the pilgrimages to the fossil fuel repositories.
    I have a question, though. It seems that every time we go to start the Prius, whether it be in morning or afternoon to return commute, the ICE will kick in after 10-20 seconds. This is usually with 3 or more bars of charge. It will remain running for several minutes. This means no EVing out of the neighborhood or out of the parking lot of work. Is this normal? Does the ICE need to kick on in order to get up to an efficient operating temp?
    Thanks.
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    It warms up the engine and the cat converter to lower emissions. When the engine is warming up, the battery does most of the pulling. From what I read, the engine in warm up is running super rich and timing super retarded and does not put out much power at all.
    I have found that if I need to move the car out of the garage to the driveway for something and back, hitting the EV mode will avoid the ICE from firing up and dump fuel for a useless warm up. Assuming the engine is not super cold, and the battery has 4 bars or more.
  3. rekniht01
    Thanks. That is what I thought. The other thing I have noticed about this is that the mpg graph stays somewhere about 25 but less than 50 during those first few minutes. Is the ICE really running that heavy?
    Would it be better off to start the Prius and let it run for a few minutes in order to get things warmed up, before leaving the house/parking spot?
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I call it a fuel dump to warm the CAT. If your battery is not too low, I would just drive it. I usually finish warming up by the time I finish crawling in the neighborhood. I would not think it would be wise to go WOT during this initial warm-up. I do not think some light duty driving would hurt, and it would yield better MPG. 25MPG is still better than 0MPG.
  5. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Letting your prius just sit in a driveway buring gas would lower your mpg. I'm sure of that. You can be easy on the car untill it warms up though.
  6. Jerry Mcl
    Jerry Mcl Junior Member
    28
    Hull, Ma
    Under federal consumer law the ice must come on within 20 seconds to recharge the battery to ensure that the battery life be prolong for the warranty. The 100k battery warranty is by federal law due to high cost of replacement for consumers. 14 states have adopted the Calif. law or green law which mandates that the manufacture guarantees the life of the battery for 150 k. Massachusetts is one state that adopted the Green Law and I am so glad...had to get a new battery at 135 k. Dealer was going to charge me $3600. plus for a new battery until I informed them of the 150 k warranty!! Talk to a Prius friend of mine from Canada and he loves it that he can leave early in the morning to work without waking the family cause his ice does not come on unless battery recharge is needed.
  7. bisco
    51,141
    trade it in on a pip! you can back out of the garage, go down the street and pick the time and place you want the ice to start, if at all. it is so sweet! the one thing that always drove me crazy with my former two pri was, you'd put it in reverse, just be backing out and wham! on comes the ice.:eek:
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Also keep in mind if your climate contol is calling for heat or defrost ypu ice will start to meet that request.
  9. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    Our Prius II starts up within 20 seconds every time when the ICE hasn't been run for several hours, but I can't imagine anyone who would be awaken by the sound of that throbbing 1800 cc engine, unless they were sleeping in the back seat.
  10. adamace1
    1,403
    193
    Charlotte, NC
    I thought the ICE must start up to warm the ICE and the catalytic converter so it will meet the emission standerds.
  11. jaymac
    jaymac membore
    179
    57
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    Can you avoid the ICE startup by use of the block heater available at the PC store? And the F/U question : is it worth the bother ?
  12. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Those are great questions, I'd also like to know those answers.
  13. bisco
    51,141
    i don't think a block heater will prevent start up, but it does reduce warm up time and cabin heat. is it worth it? kind of a subjective question. it will save a bit of gas in favor of electricity from the wall. keep in mind, a few miles down the road, all things are equal again. in really harsh climates, they can help a car start and reduce wear. but the new synthetic oils also do a good job of that.
    jaymac likes this.
  14. bwilson4web
    16,010
    My morning protocol, leaving the house for work:
    • get everything in cabin ready
    • press brake and POWER to READY
    • hit "EV" in case it works (does not work when cold or battery low)
    • exit driveway
    • modest acceleration to 25 mph (neighborhood speed) and shift to "N"
      • This minimizes the fuel burn to idle rate, the same rate seen if in "N" and parking-brake held on the driveway.
      • Continue to cycle between "D" and "N" in neighborhood.
    • reach first traffic light, usually red, use "D" to stop
    • test "D" for a couple of seconds, on and off until ICE auto-stop or light changes
      • ICE auto-stop while braked to a stop signals the catalytic converter is working
    • drive next mile or so with traffic on slow-side of traffic speed as coolant warms up while ICE coolant reaches 60-70C to reach normal hybrid driving mode
    There are two warm-up thresholds: catalytic converter light-off and ICE coolant warm-up. Catalytic converter light-off is known when the ICE auto-stops when the car is stopped. Hybrid mode occurs when the coolant is warm-enough so the ICE can auto-stop when the car is moving.
  15. brewcrew9
    brewcrew9 Member
    111
    Madison, WI
    2014 Prius Plug-in
    Does anyone have "hard Proof" that a block heater would shorten the ICE warm up time? So, when would one want a block heater on a Gen III PRIUS ? We have 2, 2011 Prius II's that are in a attached garage (rarely goes lower than 30 F) in Wisconsin winters. I just wonder if it would be worth it on a Hybrid Cars? Our local dealer here in Madison, WI claims they have sold/installed almost zero block heaters. The problems is I can see the logic in needing one and logic for not. I guess for me the breaking point might be if it shortened ICE "warm up" emissions time. Granted the heat coming on quicker would be nice too. Anyone can share good info on this I would love to know.....Thanks
  16. bwilson4web
    16,010
    1. Yes - I haven't seen any studies of the ZVW30 but we have a lot of earlier, 1.5L Prius studies showing they are effective. They can reduce the warm-up time by 2-3 minutes.
    2. No - the ZVW30 has engine coolant heat exchanger on the exhaust pipe which significantly shortens warm-up time.
  17. rokibler
    rokibler Member
    88
    31
    Cabin John, Md.
    This thread HSD behaviour during S1a & S1b warming stages | PriusChat shows exactly what coolant temp to aim for to get the best bang for the cost of electricity of the block heater. I think the net result (that I take away) is that you want to aim for 28 deg. C coolant temp went you start the car. That reduces the idle run time to the minimum 60 seconds and shortens the total warm-up time.
  18. brewcrew9
    brewcrew9 Member
    111
    Madison, WI
    2014 Prius Plug-in
    rokibler/ALL,
    How many of you run block heaters and do you notice a difference?
    Also, I know that the thermal recovery tank, that keeps the coolant warmer longer, works well. But, how long will it keep the coolant warm?, Surely not overnight in Wisconsin winters? I want to know as much as possible BEFORE I purchase block heaters for both cars......
  19. rokibler
    rokibler Member
    88
    31
    Cabin John, Md.
    First, the engine block heater (EBH) costs $59 here on the web site, and you can do the installation yourself. My daily commute is short, so 5 minutes of warm up time is 25 percent of my morning commute. I never tried to calculate the amount of fuel economy I gained with the EBH. I learned from others on PriusChat that it was worth it. I have an EBH on both the Gen 2 and Gen 3 Prii.
    Let me give you an example of how the EBH helps. In the colder weather, when I leave the office, there is a stop light about 100 yards from the office. It's a long light. It may be five minutes. If the outside temp is about freezing, and the coolant temp is about zero C when I start the car, it will idle at the stop light until it becomes 40 C. That can be more than three minutes. You can sit and watch the CONS number drop and drop and drop. In the morning, coming from the house, and starting the car with an outside temp of freezing, the EBH will have pre-heated the coolant to at least 28 C. The idle time in the morning is the minimum of 60 seconds, part of which may be stage 2, allowing me to drive using the ICE and not the battery.
    I far as I remember, the Gen 3 does not have a thermal recovery tank.
