ice motor coming on too much
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tom & lisa s c, May 7, 2014.
  1. tom & lisa s c
    tom & lisa s c Junior Member
    47
    my 2012 c is not getting the milage it used to get ,is was in a accident and since dosen t seem to get the same milage .the ice motor seems to come on every time even when 60 or 70 degrees out and when i run in a store and right out in the car the ice motor starts ,with nothing on and pulling away in ev mode .mostly it starts before i even move the car .this all seems different than it was before seems like the motor only came on when it was cold or if the heat or air was on now it dosen t matter ,the milage isn t there either .could doing a reset help this .also last night pulling away very easy there was like a ticking noise coming out of the engine at slow speed only never heard before .the tractions batteries life dosen t seem to last s as long ,that im not 100 % thou
  2. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    You win first prize for the longest sentence on this forum!
    GT-I9300 ?
  3. DKTVAV
    DKTVAV Active Member
    510
    101
    LOL. I think he doesn't like the Shift and Space keys much.
  4. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    He is a 'new wave' stream of consciousness poet.
    OP, try the reset and let us know what happened. (I think that was the question?)
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    For the punctually impaired...
    My 2012 c is not getting the milage it used to get.
    It was in an accident, and since then dosen't seem to get the same milage. The ice motor seems to come on all the time - even when it's 60 or 70 degrees out. When I run into a store and right back out, the ice motor starts even when the air or heat is not on. Pulling away in ev mode, the ice starts before I even move the car.
    This seems different than it was before the accident. It seems like the motor only came on when it was cold, or if the heat or air was on. Now it doesn't seem to matter. The milage isn't there like it was. Could doing a reset help this?
    Also, last night, pulling away at a very slow speed, there was a ticking noise coming out of the engine I never heard it before.
    The traction battery doesn't seem to last as as long as it did, either, but of that I am not 100 % sure.
    The perils of typing on phones...
    Now can we help the poor guy out?
    orenji and ftl like this.
  6. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    As before. Doing a reset won't cause any harm and might yield some clues.
  7. bisco
    49,492
    test your 12v battery if the reset doesn't work. all the best!(y)
  8. JC91006
    16,482
    8,400
    If the cause of the engine abnormality is from the accident, surely you can have the insurance company (assuming it was fixed through insurance) revisit the claim. Bring it to a dealer to get it diagnosis and repair of the problem(s) and send the bill to the insurance company.
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Punctuationally? Or was the OP late for an appointment?:rolleyes:
    Mr Incredible likes this.
  10. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    What was repaired/replaced due to the accident?
  11. Fauxknight
    Fauxknight Active Member
    210
    116
    My first thought it to check the traction battery air intake in the rear seat area. If blocked that would be a performance loss from the battery, causing issues similar to what you are experiencing, and it could be independent of any accident that has occurred. I assume there is also a fan used to pull air through that intake, which if damaged or disconnected in the accident/repairs would likely cause the same issues as a blocked vent. The likelihood of the fan being damaged seems pretty slim though, it would be centrally located so you would have had to have been T-boned in the accident for that to be an issue.
    After that I don't know. If it is accident related it would probably depend on how bad you were hit and what was repaired/replaced. If you have specifics on the work done, or even where you were hit, we might be able to make a better guess.
  12. Mr Incredible
    955
    506
    Neb
    What I ring up on the bridge isn't always what comes out of the fingers.
    ftl likes this.
  13. orenji
    orenji Senior Member
    5,884
    3,486
    Maybe their computer is broken too!
  14. tom & lisa s c
    47
    the car was hit in the back rear bumper lots of damage ,no frame damage thou .Would i even hear the fan for the battery ?There was no blockage thou in the back seat floor area where the vent was .I am still hearing the pinging noise when driving slow on a quiet road .I will have to bring it in but the dealers not going to check milage and the noise is hard to hear with lots of traffic noise .did anyone else here this noise .thanks
  15. Daniel Grevillius
    Daniel Grevillius New Member
    Newport News, VA
    What sort of reset was being talked about here?
  16. bisco
    49,492
    disconnect the 12v for a few minutes and reconnect, resets the computers.
