ICE Not Getting Fuel: Codes P0A0F and P3193
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by frankpatdiane, Jul 14, 2020.
  1. frankpatdiane
    frankpatdiane New Member
    To make a long story short: I replaced a leaking fuel line and now the ICE won't run for longer than 10 seconds and produces P0A0F and P3193 codes. I'm able to clear codes after letting it sit for an hour or so, but they come back after brief idle. Battery was disconnected in an attempt to "reset" things. No luck. Tank was at least half full when the Prius was parked and no further leakage was/is evident, therefore it's not really an out of fuel situation. More like the ICE isn't getting any.
    I wanted to keep it short, but will happily expand on anything mentioned above. I'm in a real jam, because the HV Battery state of charge will only go down with each attempt to start. I'm currently at 19%. By the way, HV modules read healthy.
    Any advice or guidance would be appreciated!
    49,477
    there are some good videos on p0a0f
    i might pour in a few gallons, and disconnect the 12v for a few minutes
  3. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    DTC P0A0F has five (5) subcodes (they may help diagnose), which OBD2 scanner are you using that isn't offering the INFs (subcodes)?
    Here is the workup for DTC P0A0F with an INF (aka subcode or detail code) of 204, 205, 533, or 534
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8CPDF%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/0a0f204.pdf
    Here is the workup for DTC P0A0F with an INF of 238 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a0f238.pdf
    Here is the workup for DTCs P3190, P3191, P3193 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8CPDF%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/2054m/cip3190a.pdf
