ICE on more frequently
Discussion in 'Gen 3 Prius Fuel Economy' started by howardc64, Feb 1, 2013.
  1. howardc64
    howardc64 Member
    91
    39
    Pacific Northwest
    2011 Prius Two 25k miles
    Been seeing a slight MPG reduction. I could easily assign it to all the winter factors (fuel, friction etc..) But didn't see this reduction last winter.
    One thing that has occurred is I can see the ICE is on more frequently. In particular, there is a well traveled road that I can usually go a few miles in electric mode keep the power demand below the midway on the ECO meter. Now the ICE will come on even if battery is fully charged and I limit the request for power. I also experience the ICE coming on going down a particular long hill where it has never come on before. Battery also nearly fully charged in this case too.
    We keep our cabin temp at 70 degrees with fan on 1 bar like we have the entire time we've owned the car.
    Anyone experienced this?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I kind of noticed an oddity myself but it was only for a couple of driving sessions this winter. Over night seemed to "correct" what I was thinking was odd behavior.
    Do you keep you climate control in "Auto"? You might try that. If you need mixed, defrost mode, press Auto first and then press Mode to get to defrost.
    A little more drastic is you might disconnect the 12v for a minute or two to "reset" the learned behavior. * warming, this will reset you fuel economy stats, radio presets ,etc.
  3. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Yes I did, then I reviewed the driving tips on this site and adjusted the way I drive and the mileage got a bit better. I think over time we tend to revert to our old driving habits, I know I do.
  4. howardc64
    howardc64 Member
    91
    39
    Pacific Northwest
    My driving pattern hadn't changed much. Very much cued to the ECO gauge for fuel economy. But this is my wife's car and she is the main driver.
    Climate control is on manual. Defrost always on and fan on 1 bar. We've had it that way forever due to the wet climate here in Northwest. Seems like this isn't a new change.
    I used Techstream (Toyota diag tool) to look at the battery parameters (attached). My car was on but just parked so ICE is not on. All looks fine. There are 3 temperatures readings on the battery with one (Temp of batt TB2) higher than the other 2 but all seems to be within reasonable range. Wonder how other people's Prius hybrid system reads.
  5. bisco
    51,141
    what were your typical mpg's this time of year and what have they dropped to?
  6. howardc64
    howardc64 Member
    91
    39
    Pacific Northwest
    Its hard to measure because my wife is more of a lead foot than I so ICE is on more often for her anyway. She also gets probably a couple of mpg less than I in a more aggressive driving style. The last 1500 miles are mostly her driving pattern and I'd say we went from 50.x to 49.x so about 1 mpg drop (we live in a hilly region). Nothing major but just surprised the ICE on frequency changed when I drive on a common route near the house.
    I'll try some kind of reset next to see if I can get rid of any bad learned habits.
  7. bisco
    51,141
    i can't imagine any driving habits that would keep the ice on more except a heavy foot. i suppose you should check the 12v, but 1 mpg is a tough measurement in the short run, you'd really have to do several tankfulls to be sure.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    1mpg or a couple percent are within margins for error and random variations. Is it a bit colder than usual? I looked through your pdf but did not notice or understand: what are the 12v battery voltages? Is the tp low? You'll need more throttle to move softer tires,
  9. howardc64
    howardc64 Member
    91
    39
    Pacific Northwest
    yes, I'm less concerned about mpg and it is very difficult to get the difference without a longer term observation. I only said 1mpg based on a short term observation. It could be 2-3 for all I know.
    I'm mainly wonder why the ICE on frequency is changed on a well traveled road when I'm driving the exact same pattern. Again, the patterns are
    - Going down a long hill, battery is nearly all charged (only 1 bar is unlit). At the bottom of the hill while coasting, ICE comes on for whatever reason with no power demand (foot not on gas). I've read the ICE will come on to prevent damage to battery and drain the excess charges. But the car has never done this before even with all the bars lit up cruising down this particular hill.
    - Driving along a flat suburban road at 35mph with most of the battery bars lit. Power demand is 1/3 on the ECO gauge. I've been able to go a couple of miles like this previously without ICE. Now ICE would randomly fireup in this condition.
    I'll try to drive this road with Techstream hooked up and see if I can see what interesting parameters change when ICE fires up.
  10. bisco
    51,141
    when i had my gen II's, the ice would sometimes come on for no explicable reason. all green bars, warm weather, after highway driving, driving 10-20 mph, but i can't say it ever changed from less often to more often.
  11. Mendel Leisk
    40,574
    Try setting the cabin temp lower, and leave it on Auto (let the computer determine the fan speed). Try to settle on a temp that keeps the fan speed low. I've found I could turn the engine on and off by raising or lowering the cabin temp.
