ICE running but no MFD indication???
Discussion in 'Gen 2 Prius Main Forum' started by mootsman, Dec 4, 2006.
  1. mootsman
    mootsman New Member
    109
    I've about gotten used to the now and then rough shutdown of the ICE....but now I've noticed that when I stop at a light the ICE will sometimes run on for a while before shutting down even though the MFD shows it as not operating. Also if I was being powered solely by the electric motor when I stop I have to press down harder than necessary on the brake pedal to cause the display to indicate that the electric motor is not running. No big deal but annoying. Anybody else notice this? Likely just MFD/sensor quirks, I guess.
  2. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    <div class='quotetop'>QUOTE(mootsman @ Dec 4 2006, 06:12 PM) [snapback]357642[/snapback]</div>
    I've noticed the ICE running and no MFD display myself. I've also had times where the MFD was showing stealth mode (yellow arrows) and 99.9 MPG, but when I came to a stop, the ICE is clearly on. Weird.
  3. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    mootsman.....Exact same problem on my 05.
  4. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Yeah, I've noticed this as well, but I don't consider it a problem. Not yet anyway........
  5. KMO
    KMO Senior Member
    1,826
    599
    Finland
    2023 Prius Prime
    The display doesn't have an ICE running indication.
    It has power flow indications, but if the engine is just running to provide cabin heat, or as part of the warm up sequence, then it's not providing motive power, so there's no indication.
  6. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    <div class='quotetop'>QUOTE(KMO @ Dec 4 2006, 07:14 PM) [snapback]357673[/snapback]</div>
    This is my understanding as well...the display shows what is propelling the car, not what is "running."
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(KMO @ Dec 5 2006, 09:14 AM) [snapback]357673[/snapback]</div>
    Also...
    It is called "Energy Monitor" not "ICE status Monitor".
    Ken@Japan
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    A careful read of the Five Stages document may help clear this up.
    [when its webserver comes back to life, that is...]
    _H*
  9. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Not uncommon! This is why many of us who are interested have resorted to a variety of secondary monitoring systems such as the CAN View, ScanGage and others more home brew types to dig in to the details. Sometime the ICE is actually burning gas sometimes it is just spinning to balance out the PSD. Some of this makes a difference in MPG and some of it does not. As noted the energy monitor screen monitors energy flows in general, but not in detail.
  10. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(ken1784 @ Dec 4 2006, 09:28 PM) [snapback]357740[/snapback]</div>
    So how does the ICE run without consuming energy? :)
  11. ken1784
    2,943
    1,381
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(jburns @ Dec 5 2006, 01:02 PM) [snapback]357780[/snapback]</div>
    It's for driving/regenerating energy only. It is not a bug, but a specification. :)
    Ken@Japan
  12. daniel
    14,487
    1,519
    Spokane, WA
    The ICE only provides energy to the wheels and/or generator when it is actually pushing on them. This usually happens when it is running. But it is possible, for example during warm-up, for the car to spin the PSD components under electrical power so that they offer no resistance to the ICE and therefore it is not supplying power to them. However this should be an unusual occurance, and I think I would generally be limited to the warm-up period. Otherwise, if it's going to burn gas it will use that to do some work, driving the car and/or recharging the battery.
