ICE shake when activated
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Justin’sPrius, Jun 17, 2021.
  1. Justin’sPrius
    Justin’sPrius Junior Member
    Pittsburgh, PA
    Hello, I am the owner of a 2011 Toyota Prius II with 166,000 miles on it. I have recently had the the fuel injectors and spark plugs (not me, a mechanic) replaced. While the car mainly runs fine, the ICE (the gas engine, not the electric) has developed a tendency to shake for a second or so before firing normally. The CEL (check engine light) is not on, and it tends to happen in lower torque situations. I had the transmission fluid flushed six months ago, but have not flushed the coolant. Does anyone have any idea what could cause this and what the solution would be?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,678
    Texas Hill Country
    Typically its a head gasket leak after the normal plugs and injectors have been done. Eventually it will start losing coolant but that can take months.
    Shutter video
  3. Mendel Leisk
    38,647
    #3 Mendel Leisk, Jun 18, 2021
    49,377
    this is becoming like the covid 12v problem
  5. Mendel Leisk
    38,647
    Wrong thread? Anyway:
    Smart charger is the vaccine. If practical.
  6. ETC(SS)
    6,542
    See also:
    "Prius Death Rattle"
    Things YOU can check If you do not do your own maintenance:
    Check the oil....look for (and smell for) coolant.
    Check the ICE coolant level in the coolant reservoir.
    It's possible that you're in the very early stages of head gasket failure, and you need to immediately address this to prevent (more) significant engine damage.
    Good Luck!
