ICE shutdown roughness
Discussion in 'Gen 2 Prius Main Forum' started by mdh, May 8, 2006.
  1. mdh
    mdh New Member
    48
    I am wondering if the following is normal… there are times when it seems to be much more noticeable when the ICE shuts off at a stop light. Sometimes it is hardly noticeable…but, there are times when you notice it more than others. Tks in advance
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(mdh @ May 8 2006, 08:37 PM) [snapback]251867[/snapback]</div>
    Pretty normal, esp. when the car is newer or the weather is cold. Nothing wrong.
  3. Tideland Prius
    16,445
    Yep. It'll be smoother if it's warmer and once broken in. It was really harsh at times when I first got the car.
  4. mdh
    mdh New Member
    48
    <div class='quotetop'>QUOTE(Tideland Prius @ May 8 2006, 07:01 PM) [snapback]251885[/snapback]</div>
    tks.. my car has about 500 miles on it.
  5. Tideland Prius
    16,445
    give it another 500 miles heh.
  6. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Mine has about 3500 on it and it does it maybe once a week... and its when its cold.... not cold outside per se, but when the engine is cold.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(windstrings @ May 8 2006, 09:55 PM) [snapback]251986[/snapback]</div>
    Windstrings where have you been? I concur that rough shut down is a product of the HSD on some occasions. A lot of speculation on what causes it, but you can live with it!
  8. daniel
    14,487
    1,519
    Spokane, WA
    The car shudders noticeably when the engine shuts off at a stop when the HSD is in Stage 3. This is the last stage before it is ready to move to Stage 4 (normal hybrid operation). In other words, when the car is not yet warmed up. Once the car is fully warmed up, this should almost never happen. (But there are oddities about HSD that nobody outside of Toyota seems to understand.) So the short answer is: don't worry: it's normal. I do not concur with people who say it will not happen once the car is broken in. Mine has 13,000 miles on it and still does this when moving from Stage 3 to Stage 4.
  9. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(hdrygas @ May 8 2006, 10:47 PM) [snapback]252016[/snapback]</div>
    Evangelizing in FHOP.
  10. windstrings
    6,280
    378
    Central Texas
    I've been in and out.. mostly tied up at Fred's... "is that a bad sign?"... opps.. could be :lol:
    Anyway... I"ve been in a whirlwind trying to sell my house.
    anyway, I get the impression as its warming up the fuel air mixture is a little unstable sometimes.
    It only does it rarely....
    I don't worry about it since so many other people have the same issue....
    I have two and they both will do it occasionally, but its so rare I barely notice.
  11. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    My Prius has ~5800 miles on it and it does this 'rough' sort of shutdown for the first ICE shutdown after it's been powered on. Usually 2-3 times a day, depending on how long the car has been parked. It's just the initial ICE shutdown where it really shudders something rough, then all the subsequent shutdowns are practically undetectable.
  12. berylrb
    berylrb Member
    308
    san francisco?
    we just hit 30K and have it quite frequently, but from reading the website it is because our typical commute is barely 4 miles, our car never warms up properly. I'll probably make a point to go the long way every now and then to just let her purr, maybe crank it up 100% to a 8 mile commute LOL.
    it seems to me that the shudder is a torquing stress, so wouldn't a long term implication be a loose motor mount? I'll ask the service repair on monday ... oh yeah, when we were in the sacramento valley we seldom ever noticed it.
    b
  13. ghostofjk
    ghostofjk New Member
    979
    Most vehicles I've had have done this. It feels like an abbreviated "dieseling".
  14. mdh
    mdh New Member
    48
    <div class='quotetop'>QUOTE(ghostofjk @ May 11 2006, 12:04 PM) [snapback]253640[/snapback]</div>
    wonder if it is bad for the ICE?
