ICE takes longer to turn on when starting car; good or bad?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, Oct 27, 2014.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    I don't know if this is too much of a newbie question or not but...
    I recently brought the car in to have the transmission fluid and spark plugs changed; it was in the garage for almost 2 weeks as I wasn't able to go in and pick it up. It was a local but trusted garage, not a dealer. Since I've had it back, when I power up the car, the ICE takes a noticeably longer time to switch on. It used to come on before I'd put it into gear, not it doesn't come on *until* I get into P or R, or at least just before sometimes. What does this mean? Is it good, bad or neutral? Is this an issue that relates the the plugs somehow? (I don't think so myself). I suspect is has something to do with the 12v battery, which I've had no noticeable problems with yet. Thanks all.
  2. JC91006
    16,496
    8,406
    This is the warm up phase of the car, I don't think there's anything wrong with your car. I would worry if the engine stays on and doesn't turn off or vise versa.
    Does it turn on at all without going into gear?
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    The engine comes on straight away if you use the front demister or rear window heater. I notice sometimes the engine will fire up when you put the car in reverse too.
    Maybe you used to reverse out before and now you drive forward instead?
    Normally though, the car takes about 7-10 seconds before the engine fires up.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It should be in the 7 second range unless the battery is near empty or the HVAC is demanding a high load like immediate heat or super AC. Don't worry about it.
  5. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    With the gen2 Prius the normal delay is 7 seconds. Putting the car in reverse will delay engine start up if the HV battery is reasonably charged.
    This is because the engine actually fights against MG2 that runs in reverse to make the car go backwards reducing the available power in reverse if the engine runs.
    John (Britprius)
  6. JC91006
    16,496
    8,406
    ever tested the delay timeframe while going in reverse?
  7. Britprius
    5,194
    1,917
    As long as the car is in reverse and the HV battery has enough charge the engine will not start. As stated above "somewhat clumsily" only MG2 gives you reverse. The engine tries to drive the car forwards because the Prius does not have a reverse gear. When the battery gets low the engine starts to use MG1 to provide current to help drive MG2.
    John (Britprius)
    JC91006 likes this.
  8. Britprius
    5,194
    1,917
    The link below shows very effectively how reverse works. Scrolling down to the animation, if you slide the button for MG2 to reverse "downwards" the outer ring that drives the wheels goes backwards, and obviously forwards "upwards" for forwards. If while in reverse you you slide the engine slider to run the engine you will see it does not assist the ring in going backwards but tries to drive it forwards also driving MG1. In trying to drive MG1 it only puts more forward torque against the outer ring going in reverse.
    Toyota Prius - Power Split Device
    John (Britprius)
    #8 Britprius, Oct 27, 2014
    JC91006 likes this.
  9. JC91006
    16,496
    8,406
    Is 65 mph the most efficient speed for the Prius? Where ICE runs at a minimum, only around 1000 rpm
  10. Britprius
    5,194
    1,917
    This is not as simple as it seems. If you play with the animation you will see that at 65 mph MG2 is running at 3835 rpm. This remains constant for a given road speed. The engine can be running at anything between 1100 rpm and 4500 rpm while MG1 can be running at anything between -6300 to +6200 with the car still doing 65 mph. This particular animation is not for the gen2 it's actually for gen1 the system is exactly the same, but rpm's will vary because of different gear ratios.
    The most efficient speed is somewhat lower than your figure.
    John (Britprius)
    #10 Britprius, Oct 27, 2014
  11. GregP507
    GregP507 Senior Member
    3,002
    480
    I pay no mind to when the ICE turns on or off. I'll start being concerned if my mileage goes down.
  12. Cadenza
    Cadenza Member
    124
    LALA Land
    Curious... Instead of waiting, I usually tap the gas pedal to activate the ICE during cold starts. Is this bad practice?
  13. Britprius
    5,194
    1,917
    If your first action is reversing it would be better not to tap the pedal, but it will do no harm to the car.
    John (Britprius)
  14. Cadenza
    Cadenza Member
    124
    LALA Land
    It's a habit that I like to get the oil pumping for the first minute before putting the car into gear.
  15. Britprius
    5,194
    1,917
    When reversing the engine normally would not be running, and fights against the electric motor that powers the car backwards.
    John (Britprius)
  16. GregP507
    3,002
    480
    It may not seem like fun, but I've gotten incredible reliability out of the vehicles I treated gently.
  17. bmparent
    bmparent Member
    159
    65
    barre ma
    So upon closer obs. today, the ICE didn't started until I put it in drive, and that was very clearly outside the 7-10 second range. Perhaps 20 sec. I haven't noticed much difference in MPG, just a 1 MPG drop in the tank average since being back from the garage which I attribute to colder weather. So I guess it's not something to worry about, but I am curious about how the system works, and why the very noticeable change would have taken place. Before the work, the ICE would come on much sooner, while sitting idle. Also, what does MG1/MG2 mean?
  18. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Unless you prevent it from turning on (like choosing reverse) the gas engine will start 7 seconds after startup. If it doesn't there is something strange going on. People are notorious for not knowing how to count time, so I would ask you use a stopwatch (like on your cell phone or an actual stopwatch) to get the time between when the car says "READY" on the dash to when the ICE starts. Do nothing but turn the car in READY, no shifter movements. It should be 7 seconds with anything above a low SOC battery.
    Motor Generator 1 and Motor Generator 2.
    They are the 2 electric drive motors that couple with the single petrol powered engine to form the hybrid drivetrain. They also act as generators producing power at various times for various reasons. Hence "MG".
  19. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    I have trouble picturing what you claim.
    How is the engine fighting against the electric motor?
    I'm supportive of forcing the early start--it gets me thru phase 1 sooner before I need to propel the vehicle (forward).
  20. GregP507
    3,002
    480
    Nothing is "fighting." The power sources are coupled to the drive-train through a power-sharing differential.
