ICE turns together with AC compressor
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by z80, Nov 11, 2024.
  1. z80
    z80 Junior Member
    26
    2014 Prius c
    I
    Hello!
    The car is Prius C One 2014. Sometimes (so far I noticed it twice in the last months) the car falls into a state when the internal combustion engine runs together with AC compressor. So, basically, I can control when ICE is on by pressing the AC button.
    If I keep it running for long enough, it charges the battery to 100%. It in turn disables regenerative breaking.
    After about 15-20 minutes the car gets back to normal, stops running ICE all the time and drops battery charge back to 80% over time.
    No OBD codes or warning lights present.
    Does this condition indicate anything? Can I just ignore it?
    Thank you!
  2. Leadfoot J. McCoalroller
    7,828
    7,294
    Pennsylvania
    2018 Prius c
    It's an indication that your hybrid battery is getting weak. If you haven't already begun, start making the preparations for a replacement.
    The AC compressor takes a lot of power. It draws it from a combination of the hybrid battery and the motor-generators in the hybrid system. If the battery hasn't got much to offer, then the balance must be made up by the engine.
    Once the cabin is close to the target temperature, the load is decreased and the behavior will seem closer to normal.
    Take it as a warning shot.
    Brian1954 likes this.
  3. z80
    z80 Junior Member
    26
    2014 Prius c
    I
    Thank you so much for the reply!
    I'm going to drive the car with OBD attached and log voltages to assess the problem further.
    Does anybody know if Toyota provides any thresholds by how much the cell voltage(s) should/can drop when feeding MG1, MG2, AC compressor?
    Thank you!
  4. Leadfoot J. McCoalroller
    7,828
    7,294
    Pennsylvania
    2018 Prius c
    They've provided something like that to the on-board battery ECU, so that it can make its own go/no-go decision about battery health.
    I understand (from reading) that one of the key data points is a 0.3V difference from one module to the next.
    I'm not aware of any place where Toyota has published this stuff in plaintext so that you can bird-dog the battery ECU, but it could be out there somewhere.
    The way they designed it, the system will try to mask early symptoms (by tagging in the engine earlier & longer) to let you extract the maximum lifetime from the traction battery. Then one day it will decide it has finally had enough, lights up the "check hybrid system" warning and leaves you a P0A80 code to read back later. That's your cue to $pend the big dollar$.
  5. z80
    z80 Junior Member
    26
    2014 Prius c
    I
    Got it! Thank you so much for the detailed explanation! I really appreciate it!
