ICE vs Battery at Highway Speed
Discussion in 'Gen 2 Prius Fuel Economy' started by rsforkner, Jun 5, 2008.
  1. rsforkner
    rsforkner Member
    369
    Boynton Beach, FL, USA
    2014 Prius v wagon
    I guess I am looking for confirmation from my observations of the MFD at highway speeds while using the CC.
    The CC tries to maintain a constant speed regardless of slight variations in the road surface including small grades. In a "standard" car this is accomplished by varying the ICE RPM (i.e. torque) slightly. You can feel these changes by lightly touching the accelerator to feel the changes.
    In the Pruis the CC does the same thing, however, instead of constantly changing the ICE RPM the Prius varies the torque by using the excess power stored in the battery through an electric motor. Thus maintaining a constant ICE RPM. This can be seen by watching the MFD and the yellow arrows indicating direction of power flow. Since the Prius is drive-by-wire the changes cannot be felt in the accelerator. It just sits there.:)
    Of course larger changes (i.e. changes in elevation) do require adjusting the ICE RPM to maintain a constant speed.
    Where am I going wrong, or am I?
    Thanks,
    Bob
  2. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    271
    Harrisburg, PA
    That correlates well with my observations as well. And, I've found that because the computer's attention doesn't wander as mine does that it generally gets better mileage than I can.
    In town, I can easily beat the cc computer if the terrain is rolling or if there are stop lights and the like.
  3. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    This is a reasonable simplification of what is happening.
    As it is, in addition to supplementing the ICE with the battery and electric motors/generators, the CC will also increase and decrease the ICE RPM as needed for optimal generation of motive power to meet the requirements of the vehicle at any given moment. Using my Scangauge, I've found that the Prius definitely does not "maintain a constant ICE RPM" while using CC.
    Additionally, while the ICE will continue to spin at all times (at a minimum of bit less than 1000 RPM) at speeds above 41 MPH, it will cut fuel and spark to the ICE when the ECU determines that it is inefficient to use the ICE.
    As I understand it, when operating CC the ECU takes into consideration:
    The current state of charge of the HV battery
    The temperature of the HV battery
    The current speed of the vehicle
    The current RPM of the ICE
    The increased/decreased amount of torque needed to maintain the set speed of the vehicle.
    It then determines the best combination of ICE RPM and electricity generation or use at each of the 2 motor/generators to create the required torque.
    If you are using CC and traveling enough downhill for gravity to accelerate the car, CC will use the torque created by the wheels to generate electricity and charge the battery to keep the car from accelerating.
    You are correct that the accelerator pedal does not move as the ECU increases or decreases the torque.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Cruise control is irrelevant to this discussion. As far as the ECU is concerned, it doesn't matter if cruise control or your foot provides the input; either way the control actions will be the same. The balance between battery and ICE is done to maximize efficiency. One of the ways to do this is to run the ICE only at efficient RPMs and loadings, which is why the ICE tends to vary its speed in stepwise increments, stopping only at efficient points.
    Cruise control becomes an issue only in that it agressively tries to maintain a set speed. A human driver will often back off a bit on uphills and accelerate a bit on downhills, often without thinking about it. We judge speed changes by sensing g loads. Being pushed back into the seat makes us think we are accelerating, while being pulled forward does the oppisite. When going uphill, gravity pulls you back into your seat, so you feel like you are going faster. The natural reaction is to back off on the accelerator. The converse is true for going downhill. Cruise control doesn't do this, which is why it feels agressive and sometimes out of control on hills.
    Tom
  5. bbald123
    386
    271
    Harrisburg, PA
    The cruise control is irrelevant from a purely control input perspective.
    It is very much relevant in maximizing MPG because it is capable of much smaller inputs into the system than I, at least, am capable of. So, on level terrain it is much better at avoiding the demand of more power than is necessary and thus doesn't cause the ICE to increase RPM as high.
