ICE warmup right before shutdown
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jul 11, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    You know how it goes...you turn the last corner to your house only to see that last precious .1 mile disappear and see the engine come on.
    So the question is...do you let it finish it's ceremonial warmup or do you do shut er down and say "NO SOUP FOR YOU!" ?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    NO SOUP:mad:
    51,986
    arghhh!!!!! :cool: i let it run in the winter until it shuts down. spring and fall for a minute or two and 30 seconds in summer. not sure why tho...
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    If you can get 100mpg bars on flat or downhill rolls in HV Eco, then it is worthwhile going into Hv mode early and saving EV for a better situation, such as uphill. I guarantee you will still have plenty of charge left going home.:cool:
  5. andyprius
    2,212
    188
    I am not sure why either, enrichen the oil conglomerates?:X3:
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is pretty important to get your engine up to full operating temperature if you are going to use it. Taken and slightly edited to fit the discussion from another source:
    Here's why it matters: One of the byproducts of engine combustion is water. When an engine reaches its operating temperature that water turns to vapor and is expunged, either out the tailpipe or the crankcase ventilation system. On a short trip, however, that water stays inside your car's engine and exhaust. Unfortunately, water is one of only three ingredients necessary to make rust (you've already got the other two, oxygen and metal), and rust kills.
    A further complication of condensation and water is that it dilutes your oil, which then does a poorer job of lubricating the engine.
  7. mrbigh
    3,686
    699
    Long Island, NY
    I let it go until it stop by itself to avoid water condensation build up
  8. markabele
    5,084
    1,782
    Nebraska
    I think letting it run til it's done is probably a good "better safe than sorry" policy to have. It uses very little gas and could aid in the longevity of the ICE.
  9. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I agree it's "better safe than sorry". If I was just arriving home and the ICE was still warming up, I'd probably wait (although this never happens to me, at least not yet).
    But what I cant stand is, if I'm moving my car around on the driveway (with no charge) to wash it and the engine comes on.. that warm-up seems to take forever. I did wait in the past. But I dont anymore.
  10. bisco
    51,986
    that's why i plug in before moving, only takes a minute for enough charge.
    markabele likes this.
  11. 3PriusMike
    3,100
    2,419
    Silicon Valley
    I generally will try and switch to HV when I know it will be close so that I save an EV mile or two for the final drive home. If the ICE does come on, I just shut it off.
    Mike
  12. markabele
    5,084
    1,782
    Nebraska
    Hopefully you never leave any EV remaining.
  13. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    If I'm just around the corner from my house and I run out of EV and HV power? I'll get out and push it home :D using LP (Leg Power).
    rockerdan likes this.
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    You da man! Go leg power! :D
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    I sure hope those are good looking legs! :eek:
  16. markabele
    5,084
    1,782
    Nebraska
    creepy
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
    My point exactly! :whistle:
  18. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Many times I end up with two to three tenths of a mile EV when I get home. But I figure it is much better to run HV efficiently (usually freeway speeds) for a couple of miles with a complete warmup cycle than to run out of EV a few blocks from home and have the ICE start and run while sitting some of the 3 or 4 red lights I usually get between the freeway and home. And then, if I need to move the car in/out of the garage I have enough EV to do it without the ICE starting. As it is I get 70-80% EV anyway...I'm not losing much by not getting that last 0.01%.
    Mike
  19. markabele
    5,084
    1,782
    Nebraska
    The engine during warmup doesn't contribute to propulsion. So not only are you leaving EV on the table but you are not getting to use the extra mile+ that is in the HV. If you need to move it just plug it in for a few minutes first like someone else suggested.
  20. andyprius
    2,212
    188
    Sounds perfect to me.
